Ok did the above. Tried another file it didnt remove it looked in log same error
2015-01-08 15:29:47 ERROR ::MAIN: Unable to locate a section with subsection:UNCAT enabled in your autoProcessMedia.cfg, exiting!
2015-01-08 15:29:47 ERROR ::MAIN: A problem was reported in the /usr/local/share/nzbToMedia/TorrentToMedia.py script.
Here is my cfg file see anything that looks wrong?
[Torrent]
###### clientAgent - Supported clients: utorrent, transmission, deluge, rtorrent, vuze, other
clientAgent = transmission
###### useLink - Set to hard for physical links, sym for symbolic links, move to move, and no to not use links (copy)
useLink = move
###### outputDirectory - Default output directory (categories will be appended as sub directory to outputDirectory)
outputDirectory = /mnt/media/downloads/transmission/complete
###### Enter the default path to your default download directory (non-category downloads). this directory is protected by safe_mode.
default_downloadDirectory = ""
###### Other categories/labels defined for your downloader. Does not include CouchPotato, SickBeard, HeadPhones, Mylar categories.
categories = music_videos, pictures, software, manual
###### A list of categories that you don't want to be flattened (i.e preserve the directory structure when copying/linking.
noFlatten = pictures, manual
###### uTorrent Hardlink solution (You must edit this if your using TorrentToMedia.py with uTorrent)
uTorrentWEBui =
http://localhost:8090/gui/
uTorrentUSR = your username
uTorrentPWD = your password
###### Transmission (You must edit this if your using TorrentToMedia.py with uTorrent)
TransmissionHost = localhost
TransmissionPort = 9091
TransmissionUSR = your username
TransmissionPWD = your password
#### Deluge (You must edit this if your using TorrentToMedia.py with deluge. Note that the host/port is for the deluge daemon, not the webui)
DelugeHost = localhost
DelugePort = 58846
DelugeUSR = your username
DelugePWD = your password
###### ADVANCED USE - ONLY EDIT IF YOU KNOW WHAT YOU'RE DOING ######
deleteOriginal = 1
