[FreeNAS 9 Plugins] - SAB / SB / CP / HP / Maraschino / HTPC / Mylar / LL / Gamez
Dmitry Nevozhay
Hi Dmitry,
Its not intuitive, but you actually just "install" the sabnzbd plugin and it will automatically create a jail named sabnzbd_1
From there you can select the jail and click the brown box icon, which will allow you to upload/install other plugins into the same jail.
Hope that help.
Thank you, Biggeek. But it's not a perfect solution. Such jail will be auto-deleted in case of deinstalling the corresponding plugin... Right?
As well as I would control the name of jail.
Any other ideas?
I consider this issue as a bug or artificial limitation of new version. Are you agreed?
Joshua Parker Ruehlig
Any other ideas?
No, it's only deleted when all plugins are deleted from the jail. The first plugin installed is not special and only decides the naming.
Unfortunately you can't chose the name of plugin jails anymore (by creating a plugin jail without installing a plugin). You can file a bug report for this, but iX purposely made this change. I've decided to live with it and have a jail named "sabnzbd_1".
Well not sure how to turn them on. But looks like Transmission is still randomly turning off. Not sure why.
i think this should enable loging
service transmission onestop
sysrc 'transmission_flags=-e /tmp/transmission.log'
service transmission start
Ray Milyard
Joshua here is a log. I don't see anything
[2014-12-31 06:59:01.797 MST] Transmission 2.84 (14307) started (session.c:736)
[2014-12-31 06:59:01.797 MST] RPC Server Serving RPC and Web requests on port 127.0.0.1:9091/transmission/ (rpc-server.c:1033)
[2014-12-31 06:59:01.797 MST] UDP Failed to set receive buffer: No buffer space available (tr-udp.c:59)
[2014-12-31 06:59:01.797 MST] UDP Failed to set receive buffer: requested 4194304, got 42080 (tr-udp.c:78)
[2014-12-31 06:59:01.797 MST] DHT Reusing old id (tr-dht.c:306)
[2014-12-31 06:59:01.797 MST] DHT Bootstrapping from 85 IPv4 nodes (tr-dht.c:154)
[2014-12-31 06:59:01.797 MST] Using settings from "/usr/pbi/transmission-amd64/etc/transmission/home" (daemon.c:557)
[2014-12-31 06:59:01.797 MST] Saved "/usr/pbi/transmission-amd64/etc/transmission/home/settings.json" (variant.c:1214)
[2014-12-31 06:59:01.797 MST] Saved pidfile "/var/run/transmission/daemon.pid" (daemon.c:569)
[2014-12-31 06:59:01.797 MST] Blocklist "blocklist.bin" contains 228955 entries (blocklist.c:113)
[2014-12-31 06:59:01.797 MST] Loaded 6 torrents (session.c:1992)
[2014-12-31 06:59:01.797 MST] Port Forwarding (NAT-PMP) initnatpmp succeeded (0) (natpmp.c:70)
[2014-12-31 06:59:01.797 MST] Port Forwarding (NAT-PMP) sendpublicaddressrequest succeeded (2) (natpmp.c:70)
[2014-12-31 06:59:03.798 MST] Port Forwarding (UPnP) Found Internet Gateway Device "http://10.0.1.1:5000/Public_UPNP_C3" (upnp.c:223)
[2014-12-31 06:59:03.798 MST] Port Forwarding (UPnP) Local Address is "10.0.1.101" (upnp.c:225)
[2014-12-31 06:59:03.798 MST] Port Forwarding (UPnP) Port forwarding through "http://10.0.1.1:5000/Public_UPNP_C3", service "urn:schemas-upnp-org:service:WANIPConne$
[2014-12-31 06:59:03.798 MST] Port Forwarding (UPnP) Port forwarding successful! (upnp.c:303)
[2014-12-31 06:59:03.798 MST] Port Forwarding Port Forwarding (port-forwarding.c:92)
[2014-12-31 06:59:03.798 MST] Changed open file limit from 463176 to 1024 (fdlimit.c:527)
[2014-12-31 06:59:04.798 MST] ultimate+survival+alaska+s02e01+arctic+battleground+720p+hdtv+x264+dhd unregistered torrent (announcer.c:996)
[2014-12-31 06:59:04.798 MST] ultimate+survival+alaska+s02e01+arctic+battleground+720p+hdtv+x264+dhd Retrying announce in 20 seconds. (announcer.c:1005)
[2014-12-31 06:59:12.798 MST] Jersey.Boys.2014.1080p.BluRay.REMUX.AVC.DTS-HD.MA.5.1-RARBG Starting IPv4 DHT announce (poor, 13 nodes) (tr-dht.c:576)
[2014-12-31 06:59:12.798 MST] ultimate+survival+alaska+s02e01+arctic+battleground+720p+hdtv+x264+dhd Starting IPv4 DHT announce (poor, 13 nodes) (tr-dht.c:576)
[2014-12-31 06:59:17.798 MST] ultimate+survival+alaska+s02e09+river+of+doom+720p+hdtv+x264+dhd Starting IPv4 DHT announce (poor, 16 nodes) (tr-dht.c:576)
[2014-12-31 06:59:18.798 MST] [ www.Torrenting.com ] - Ultimate.Survival.Alaska.S02E07.Vice.Grip.720p.HDTV.x264-DHD Starting IPv4 DHT announce (poor, 16 nodes) (tr-$
[2014-12-31 06:59:19.798 MST] [ www.Torrenting.com ] - Ultimate.Survival.Alaska.S02E11.Deep.Dark.Woods.720p.HDTV.x264-DHD Starting IPv4 DHT announce (poor, 16 nodes$
[2014-12-31 06:59:23.798 MST] ultimate+survival+alaska+s02e01+arctic+battleground+720p+hdtv+x264+dhd unregistered torrent (announcer.c:996)
[2014-12-31 06:59:23.798 MST] ultimate+survival+alaska+s02e01+arctic+battleground+720p+hdtv+x264+dhd Retrying announce in 351 seconds. (announcer.c:1005)
that's from right before crashing? maybe its best you create a new thread or ask on the transmission forums. I don't think I can help much with this.. I'm just the package maintainer, lol
That's it. Look in FreeNAS plugins after that and it's off.
when it's off, can you restart it just by clicking the service start button?
Yes. Or command line. Both restart it. It seems to be totally random when turns off. Sometimes in minutes. Last night ran about 7 hours.
strange, doesn't sound like it's universal problem, something with your specific setup. and sucks there's no clues to follow. transmission people might know more about tracing down the issue
strange, so it's never an issue starting up, maybe it did start but crashed.
please debug with the transmission guys, there's nothing I can deduce from the clues.
xCatalystx
Quick question. Any idea why this is occurring when transmission is started? Using the latest plugin Transmission 2.84 (14307)
root@transmission_1:/ # service transmission start
usage: chown [-fhvx] [-R [-H | -L | -P]] owner[:group] file ...
chown [-fhvx] [-R [-H | -L | -P]] :group file ...
Starting transmission.
cause i set transmission_download_dir to '' so that you can set this setting from other interfaces than FreeNAS. the script isn't smart enough to know that its actually not set to anything but if I don't set it the default is used.
xCatalystx
Fair enough.
Another quick one; im getting this line in my daily email "pid 76370 (Plex Media Scanner), uid 972: exited on signal 11". I've checked "Plex Media Server.log" and "Plex Media Scanner.log" but cannot find any lines referring to a exit on signal 11. Any ideas? Also using the latest plugin but with the updated pms. Doesn't seem to be causing me any problems that im aware of and my plexdb is pretty big (meta alone is 40gb). There forums seem pretty empty on the subject.
Fair enough.
probably best to ask in a new thread. I don't use/support plex.
xCatalystx
