[FreeNAS 9 Plugins] - SAB / SB / CP / HP / Maraschino / HTPC / Mylar / LL / Gamez
MtK
@Joshua Parker Ruehlig:
the cron (blacklist update) doesn't work.
trying manually returns:
# /usr/local/bin/transmission-remote --blocklist-update
/usr/local/bin/transmission-remote: Command not found.
the file is there (as symlink):
# ls -l /usr/local/bin/ | grep transmission
lrwxr-xr-x    1 root  wheel       53 Dec 17 18:21 transmission-daemon -> /usr/pbi/transmission-amd64/.sbin/transmission-daemon
lrwxr-xr-x    1 root  wheel       53 Dec 17 18:21 transmission-remote -> /usr/pbi/transmission-amd64/.sbin/transmission-remote
is there a way to run the script manually to test it out?
I think so, nzbToMedia wiki / forum section in SR forums is the best place to check
sweet mother of god i broke it again....updated sickrage from the web ui and get this....it stalled while updating so i restarted the plugin and got this.
Error
No module named pat
Traceback
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/tornado/web.py", line 1292, in _stack_context_handle_exception raise_exc_info((type, value, traceback))
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/tornado/stack_context.py", line 314, in wrapped ret = fn(*args, **kwargs)
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/tornado/concurrent.py", line 226, in lambda future: callback(future.result()))
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/concurrent/futures/_base.py", line 400, in result return self.__get_result()
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/concurrent/futures/_base.py", line 359, in __get_result reraise(self._exception, self._traceback)
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/concurrent/futures/_compat.py", line 107, in reraise exec('raise exc_type, exc_value, traceback', {}, locals_)
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/concurrent/futures/thread.py", line 61, in run result = self.fn(*self.args, **self.kwargs)
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/sickbeard/webserve.py", line 229, in async_call result = function(**kwargs)
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/sickbeard/webserve.py", line 681, in index t = PageTemplate(rh=self, file="home.tmpl")
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/sickbeard/webserve.py", line 101, in __init__ super(PageTemplate, self).__init__(*args, **kwargs)
File "/usr/pbi/sickrage-amd64/lib/python2.7/site-packages/Cheetah/Template.py", line 1259, in __init__ self._compile(source, file, compilerSettings=compilerSettings)
File "/usr/pbi/sickrage-amd64/lib/python2.7/site-packages/Cheetah/Template.py", line 1553, in _compile keepRefToGeneratedCode=True)
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/sickbeard/webserve.py", line 144, in compile return super(PageTemplate, self).compile(*args, **kwargs)
File "/usr/pbi/sickrage-amd64/lib/python2.7/site-packages/Cheetah/Template.py", line 788, in compile exec(co, mod.__dict__)
File "/var/db/sickrage/cache/cheetah/_usr_pbi_sickrage_amd64_share_sickrage_SickRage_gui_slick_interfaces_default_home_tmpl.py", line 30, in import os.pat
ImportError: No module named pat
Request Info
body:
files: {}
protocol: http
connection:
body_arguments: {}
uri: /sickrage/home/
query_arguments: {}
_start_time: 1418996504.79
headers: {'Accept-Language': 'en-US,en;q=0.8', 'Accept-Encoding': 'gzip, deflate, sdch', 'Connection': 'close', 'Accept': 'text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8', 'User-Agent': 'Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/39.0.2171.95 Safari/537.36', 'Host': '127.0.0.1:8081', 'Cookie': 'advanced_toggle_checked=1; wanted_view2=details; manage_view2=details; snatched_view2=list; soon_view2=thumbs; suggestions_charts_menu_selected=charts; late_view2=list'}
host: 127.0.0.1:8081
version: HTTP/1.0
arguments: {}
_finish_time: None
query:
path: /sickrage/home/
method: GET
remote_ip: 127.0.0.1
wow... guess it's not the best time to be a SR user. we had a few good months of stable updates there...
thanks for noticing! I use that on a freebsd machine but forgot to translate it to freenas plugins. I'll fix it up.
should be /usr/pbi/transmission-amd64/ instead of /usr/local
Edit
so ill need to link some libraries to get this to work. I'll make sure it works by the time 2.84 is official. hoping it all gets done this weekend.
Gerald Young
@MtK
thanks got it sorted...again..but need to seed the torrents from TD do i just mark
"script-torrent-done-enabled": true,
to false? tried just changing settings in SR but won't keep seeding in transmission..
@MtK
you can set it to false, but then postprocessing wouldn't happen.
you can accomplish what you want by linking the file instead of moving it and changing a few other options. you need to edit your nzbtomedia.cfg and SR/CP settings. im not the best person to ask cause I don't do it that way.
Ray Milyard
So upgraded to 9.3 and now getting this message:
WARNING: Firmware version 19 does not match driver version 16 for /dev/mps0
Also Transmission not working. Getting errors like this:
American.Horror.Story.S04E10.1080p.WEB-DL.DD5.1.H.264-ECI[rarbg]
Error: No data found! Ensure your drives are connected or use "Set Location". To re-download, remove the torrent and re-add it.
Thinking maybe should reinstall and go back to 9.2.x?
not sure. that driver error is probably best debugged in another section of the forum.
as for transmission, are you using v2.82 or 2.84_1?
2.84_1 that I linked has a typo but people here edited the config to fix the issue
Ray Milyard
284_1 I am pretty sure.
What/where should I be editing this?
that transmission error may be fixable. edit the transmission config and you'll see the typo (duplicate incomplete entry). fix it, start transmission and it should work
Ray Milyard
I see this:
"incomplet-dir": "/mnt/media/downloads/transmission/incomplete",
"incomplete-dir": "/mnt/media/downloads/transmission/incomplete",
in the:
/usr/pbi/transmission-amd64/etc/transmission/home/settings.json
When I take the first line out and restart transmission it comes back
I see this:
in the:
your config looks fine then. did you check to see the mointpoint into the jail is there.
does transmission have permissions to write in it's download directories? it should be run be 'media'. check 'ps aux'
Ray Milyard
Think I got it. I think I messed up something else but now files seems to be downloading in the /transmission/incomplete folder like it should. Thanks for the help. I tell you I am learning more and more about FreeBSD etc then even thought I would. lol. Windows admin here.
lol, nice. can't make things too easy, otherwise no one would learn =P
David Prince
I get the following when trying to open sickrage:
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/tornado/web.py", line 1313, in _execute
result = self.prepare()
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/tornado/web.py", line 2002, in prepare
raise HTTPError(self._status_code)
HTTPError: HTTP 404: Not Found
Sickrage seems to be having some issues. Might leave it for a bit and reinstall in a few days. Best way to reinstall is just delete plugin reinstall and then modify any necessary files?
Are you trying to install following my blog of in it's own jail?
If following my blog just yes, just delete and reinstall. That would basically refresh the SickRage source files.
If on it's own jail, I'd just install a second instance only delete the first instance once you're ready.
