Joshua Parker Ruehlig
- Dec 5, 2011
when you go to CP is it http://jailip:5050 or http://jailip:5050/couchpotato?I'm not sure that it's listening how would i check?
#user nobody;
worker_processes 8;
#error_log logs/error.log;
#error_log logs/error.log notice;
#error_log logs/error.log info;
#pid logs/nginx.pid;
events {
worker_connections 1024;
http {
include mime.types;
default_type application/octet-stream;
#log_format main '$remote_addr - $remote_user [$time_local] "$request" '
# '$status $body_bytes_sent "$http_referer" '
# '"$http_user_agent" "$http_x_forwarded_for"';
#access_log logs/access.log main;
sendfile on;
#tcp_nopush on;
#keepalive_timeout 0;
keepalive_timeout 65;
#gzip on;
server {
location ^~ /sabnzbd {
proxy_pass http://127.0.0.1:8080;
location ^~ /sickrage {
proxy_pass http://127.0.0.1:8081;
location ^~ /couchpotato {
proxy_pass http://127.0.0.1:5050;
location ^~ /transmission {
proxy_pass http://127.0.0.1:9091;
you didn't answer my question.only one that does that is SAB.. sick and cp don't somthing wrong in nginx.conf maybe?
Code:#user nobody; worker_processes 8; #error_log logs/error.log; #error_log logs/error.log notice; #error_log logs/error.log info; #pid logs/nginx.pid; events { worker_connections 1024; } http { include mime.types; default_type application/octet-stream; #log_format main '$remote_addr - $remote_user [$time_local] "$request" ' # '$status $body_bytes_sent "$http_referer" ' # '"$http_user_agent" "$http_x_forwarded_for"'; #access_log logs/access.log main; sendfile on; #tcp_nopush on; #keepalive_timeout 0; keepalive_timeout 65; #gzip on; server { location ^~ /sabnzbd { proxy_pass http://127.0.0.1:8080; } location ^~ /sickrage { proxy_pass http://127.0.0.1:8081; } location ^~ /couchpotato { proxy_pass http://127.0.0.1:5050; } location ^~ /transmission { proxy_pass http://127.0.0.1:9091; } } }
welcome, glad its working!@Joshua Parker Ruehlig
Got it! I had the web root in CP set to couchpotato not /couchpotato...Thanks again for all your help dude!
maybe fix up the transmission config, the pbi I posted has a typo. check for the word "incomplete".Hi,
I followed the guide and am getting this error in transmission:
Error: Permission denied (/mnt/media/downloads/transmission/complete/tv/[name of show]
not the one i have linked. you can work around the bug if you want thoughIs transmission working now?
yeah, just copy your setting over from "incomplet" to "incomplete"I see a typo / double entry in transmissions settings.json
Is this what needs to be fixed?
Thanks,
David
is there a way to run the script manually to test it out?I wouldn't do it that way. it should still work, but I believe 'moving' actually means a read/write/delete routine instead of just changing the pointer. if they are the same dataset it's more efficient to use a single mointpoint
Error
No module named pat
Traceback
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/tornado/web.py", line 1292, in _stack_context_handle_exception raise_exc_info((type, value, traceback))
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/tornado/stack_context.py", line 314, in wrapped ret = fn(*args, **kwargs)
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/tornado/concurrent.py", line 226, in lambda future: callback(future.result()))
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/concurrent/futures/_base.py", line 400, in result return self.__get_result()
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/concurrent/futures/_base.py", line 359, in __get_result reraise(self._exception, self._traceback)
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/concurrent/futures/_compat.py", line 107, in reraise exec('raise exc_type, exc_value, traceback', {}, locals_)
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/concurrent/futures/thread.py", line 61, in run result = self.fn(*self.args, **self.kwargs)
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/sickbeard/webserve.py", line 229, in async_call result = function(**kwargs)
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/sickbeard/webserve.py", line 681, in index t = PageTemplate(rh=self, file="home.tmpl")
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/sickbeard/webserve.py", line 101, in __init__ super(PageTemplate, self).__init__(*args, **kwargs)
File "/usr/pbi/sickrage-amd64/lib/python2.7/site-packages/Cheetah/Template.py", line 1259, in __init__ self._compile(source, file, compilerSettings=compilerSettings)
File "/usr/pbi/sickrage-amd64/lib/python2.7/site-packages/Cheetah/Template.py", line 1553, in _compile keepRefToGeneratedCode=True)
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/sickbeard/webserve.py", line 144, in compile return super(PageTemplate, self).compile(*args, **kwargs)
File "/usr/pbi/sickrage-amd64/lib/python2.7/site-packages/Cheetah/Template.py", line 788, in compile exec(co, mod.__dict__)
File "/var/db/sickrage/cache/cheetah/_usr_pbi_sickrage_amd64_share_sickrage_SickRage_gui_slick_interfaces_default_home_tmpl.py", line 30, in import os.pat
ImportError: No module named pat
Request Info
body:
files: {}
protocol: http
connection:
body_arguments: {}
uri: /sickrage/home/
query_arguments: {}
_start_time: 1418996504.79
headers: {'Accept-Language': 'en-US,en;q=0.8', 'Accept-Encoding': 'gzip, deflate, sdch', 'Connection': 'close', 'Accept': 'text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8', 'User-Agent': 'Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/39.0.2171.95 Safari/537.36', 'Host': '127.0.0.1:8081', 'Cookie': 'advanced_toggle_checked=1; wanted_view2=details; manage_view2=details; snatched_view2=list; soon_view2=thumbs; suggestions_charts_menu_selected=charts; late_view2=list'}
host: 127.0.0.1:8081
version: HTTP/1.0
arguments: {}
_finish_time: None
query:
path: /sickrage/home/
method: GET
remote_ip: 127.0.0.1
yayyyy!is there a way to run the script manually to test it out?
My logic would suggest to remove the plugin and upload (!!! see the instructions on the blog) it again...sweet mother of god i broke it again....updated sickrage from the web ui and get this....it stalled while updating so i restarted the plugin and got this.
Code:Error No module named pat Traceback Traceback (most recent call last): File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/tornado/web.py", line 1292, in _stack_context_handle_exception raise_exc_info((type, value, traceback)) File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/tornado/stack_context.py", line 314, in wrapped ret = fn(*args, **kwargs) File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/tornado/concurrent.py", line 226, in lambda future: callback(future.result())) File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/concurrent/futures/_base.py", line 400, in result return self.__get_result() File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/concurrent/futures/_base.py", line 359, in __get_result reraise(self._exception, self._traceback) File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/concurrent/futures/_compat.py", line 107, in reraise exec('raise exc_type, exc_value, traceback', {}, locals_) File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/concurrent/futures/thread.py", line 61, in run result = self.fn(*self.args, **self.kwargs) File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/sickbeard/webserve.py", line 229, in async_call result = function(**kwargs) File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/sickbeard/webserve.py", line 681, in index t = PageTemplate(rh=self, file="home.tmpl") File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/sickbeard/webserve.py", line 101, in __init__ super(PageTemplate, self).__init__(*args, **kwargs) File "/usr/pbi/sickrage-amd64/lib/python2.7/site-packages/Cheetah/Template.py", line 1259, in __init__ self._compile(source, file, compilerSettings=compilerSettings) File "/usr/pbi/sickrage-amd64/lib/python2.7/site-packages/Cheetah/Template.py", line 1553, in _compile keepRefToGeneratedCode=True) File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/sickbeard/webserve.py", line 144, in compile return super(PageTemplate, self).compile(*args, **kwargs) File "/usr/pbi/sickrage-amd64/lib/python2.7/site-packages/Cheetah/Template.py", line 788, in compile exec(co, mod.__dict__) File "/var/db/sickrage/cache/cheetah/_usr_pbi_sickrage_amd64_share_sickrage_SickRage_gui_slick_interfaces_default_home_tmpl.py", line 30, in import os.pat ImportError: No module named pat Request Info body: files: {} protocol: http connection: body_arguments: {} uri: /sickrage/home/ query_arguments: {} _start_time: 1418996504.79 headers: {'Accept-Language': 'en-US,en;q=0.8', 'Accept-Encoding': 'gzip, deflate, sdch', 'Connection': 'close', 'Accept': 'text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8', 'User-Agent': 'Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/39.0.2171.95 Safari/537.36', 'Host': '127.0.0.1:8081', 'Cookie': 'advanced_toggle_checked=1; wanted_view2=details; manage_view2=details; snatched_view2=list; soon_view2=thumbs; suggestions_charts_menu_selected=charts; late_view2=list'} host: 127.0.0.1:8081 version: HTTP/1.0 arguments: {} _finish_time: None query: path: /sickrage/home/ method: GET remote_ip: 127.0.0.1
DVitoD...
Blog is here.
https://www.jruehlig.com/wordpress/installation-configuration-of-freenas-plugins/
