[FreeNAS 9 Plugins] - SAB / SB / CP / HP / Maraschino / HTPC / Mylar / LL / Gamez
MtK
Great, let me know if I can help with anything...
also SickRage stopped working in the middle of the first internal update...
MtK
btw, Transmission 2.84_1, after install FN thinks there is an update, which makes the plugin stop working completely
Joshua Parker Ruehlig
I know, FN always wants the version from the repo. I'll have the repo updated soon.
see a few posts back.
people already started complaining on the SR forum so you can join in their discussion. for now my advice is to not update SR
Should the guide on the blog work? Think missing something or watch the youtube video and do that? If it's that someone the lines to copy are missing.
I don't exactly understand what you're asking. the blog gets continually updated, its nearly perfect.
the YouTube video doesn't get updated, so the extra lines are no longer needed.
Ray Milyard
So I am looking at guide now. So the other plugins are you just installing them in the sabnzbd_1 jail?
yup, only way I think we can do it anymore
MtK
service transmission restart
Stopping transmission.
Waiting for PIDS: 94058.
usage: chown [-fhvx] [-R [-H | -L | -P]] owner[:group] file ...
      chown [-fhvx] [-R [-H | -L | -P]] :group file ...
Starting transmission.
not sure what you are saying? I set transmissions_download_dir in the rc.conf to "" so that it can be edited from the config file from, for example, the RPC interface, otherwise it only can be edited from the FN interface.
this causes the startup to spit out an error, but everything should still work.
MtK
as you can see the chown command in not properly ran.
why does it matter? the plugin still works for you?
if we don't do it this way, only the FN interface can edit the download folder option. the logic in the init script can be edited to know it's an empty variable, even though it's set. but this change would be in the upstream transmission port.
MtK
How does the SEED TIME works (if) with the new post-process method (external script)?
you can configure all of that, either in CP/SR or nzbToMedia. I personally have my torrents deleted immediately after the file is moved, but you could alternatively copy/link the file and continue to seed.
nzbToMedia wiki and playing around with the settings is the best place to look.
MtK
it is configured in CP/SR but it just moved all the files and therefor download/seed stopped, which means I will have to re-download...
if you move/copy/link them back, I think there's a way to tell transmission to verify the files. but I don't know, cause I try to do the exact opposite, minimize seeding.
MtK
yes, but some Torrents require a minimum seed time... :/
and Torrent file was removed as well
SR was fixed so feel free to upgrade.
MtK
the scripts seem to run when a Torrent has finished downloading, but it tries to do a lot of things (specially deleting and marking failed download) except moving the finished file:
2014-12-18 11:27:33 INFO    ::MAIN: #########################################################
2014-12-18 11:27:33 INFO    ::MAIN: ## ..::[TorrentToMedia.py]::.. ##
2014-12-18 11:27:33 DEBUG   ::MAIN: Options passed into TorrentToMedia: ['/usr/local/share/nzbToMedia/TorrentToMedia.py']
2014-12-18 11:27:33 DEBUG   ::MAIN: Adding TORRENT download info for directory /mnt/Downloads/Transmission/Complete/TVShows to database
2014-12-18 11:27:33 DEBUG   ::MAIN: Received Directory: /mnt/Downloads/Transmission/Complete/TVShows | Name: {NAME_OF_TVSHOW_DIR} | Category:
2014-12-18 11:27:33 DEBUG   ::MAIN: SEARCH: Found Category: TVShows in directory structure
2014-12-18 11:27:33 INFO    ::MAIN: SEARCH: Found torrent directory {NAME_OF_TVSHOW_DIR} in input directory directory /mnt/Downloads/Transmission/Complete/TVShows
2014-12-18 11:27:33 INFO    ::MAIN: SEARCH: Setting inputDirectory to /mnt/Downloads/Transmission/Complete/TVShows/{NAME_OF_TVSHOW_DIR}
2014-12-18 11:27:33 DEBUG   ::MAIN: Determined Directory: /mnt/Downloads/Transmission/Complete/TVShows/{NAME_OF_TVSHOW_DIR} | Name: {NAME_OF_TVSHOW_DIR} | Category: TVShows
2014-12-18 11:27:33 INFO    ::MAIN: Auto-detected SECTION:SickBeard
2014-12-18 11:27:33 DEBUG   ::MAIN: Stopping torrent {NAME_OF_TVSHOW_DIR} in transmission while processing
2014-12-18 11:27:38 INFO    ::MAIN: Output directory set to: /mnt/media/TVShows/{NAME_OF_TVSHOW_DIR}
2014-12-18 11:27:38 DEBUG   ::MAIN: Scanning files in directory: /mnt/Downloads/Transmission/Complete/TVShows/{NAME_OF_TVSHOW_DIR}
2014-12-18 11:27:38 DEBUG   ::MAIN: Found 2 files in /mnt/Downloads/Transmission/Complete/TVShows/{NAME_OF_TVSHOW_DIR}
2014-12-18 11:27:38 DEBUG   ::MAIN: Checking for archives to extract in directory: /mnt/media/TVShows/{NAME_OF_TVSHOW_DIR}
2014-12-18 11:27:38 INFO    ::MAIN: FLATTEN: Flattening directory: /mnt/media/TVShows/{NAME_OF_TVSHOW_DIR}
2014-12-18 11:27:38 WARNING ::MAIN: Found no media files in /mnt/media/TVShows/{NAME_OF_TVSHOW_DIR}
2014-12-18 11:27:38 INFO    ::MAIN: Calling SickBeard:TVShows to post-process:{NAME_OF_TVSHOW_DIR}
2014-12-18 11:27:38 INFO    ::MAIN: Attempting to auto-detect TVShows fork
2014-12-18 11:27:38 INFO    ::MAIN: SickBeard:TVShows fork auto-detection successful ...
2014-12-18 11:27:38 INFO    ::MAIN: SickBeard:TVShows fork set to sickrage
2014-12-18 11:27:38 POSTPROCESS::SICKBEARD: FAILED: The download failed. Sending 'failed' process request to sickrage branch
2014-12-18 11:27:38 DEBUG   ::SICKBEARD: Opening URL: http://localhost:8081/sickrage/home/postprocess/processEpisode with params: {'nzbName': '{NAME_OF_TVSHOW_DIR}', 'quiet': 1, 'failed': 1, 'dir': '/mnt/media/TVShows/{NAME_OF_TVSHOW_DIR}'}
2014-12-18 11:27:38 POSTPROCESS::SICKBEARD: Processing folder /mnt/media/TVShows/{NAME_OF_TVSHOW_DIR}
2014-12-18 11:27:38 POSTPROCESS::SICKBEARD: TV_DOWNLOAD_DIR: /mnt/Downloads/Transmission/Complete/TVShows
2014-12-18 11:27:38 POSTPROCESS::SICKBEARD: PostProcessing Path: /mnt/media/TVShows
2014-12-18 11:27:38 POSTPROCESS::SICKBEARD: PostProcessing Dirs: [u'{NAME_OF_TVSHOW_DIR}']
2014-12-18 11:27:38 POSTPROCESS::SICKBEARD: PostProcessing Files: []
2014-12-18 11:27:38 POSTPROCESS::SICKBEARD: PostProcessing VideoFiles: []
2014-12-18 11:27:38 POSTPROCESS::SICKBEARD: PostProcessing RarContent: []
2014-12-18 11:27:38 POSTPROCESS::SICKBEARD: PostProcessing VideoInRar: []
2014-12-18 11:27:38 POSTPROCESS::SICKBEARD: Processing folder {NAME_OF_TVSHOW_DIR}
2014-12-18 11:27:38 POSTPROCESS::SICKBEARD: Failed download detected: ({NAME_OF_TVSHOW_DIR}, /mnt/media/TVShows/{NAME_OF_TVSHOW_DIR})
2014-12-18 11:27:38 POSTPROCESS::SICKBEARD: Deleted folder: /mnt/media/TVShows/{NAME_OF_TVSHOW_DIR}
2014-12-18 11:27:38 POSTPROCESS::SICKBEARD: Failed Download Processing succeeded: ({NAME_OF_TVSHOW_DIR}, /mnt/media/TVShows/{NAME_OF_TVSHOW_DIR})
2014-12-18 11:27:38 POSTPROCESS::SICKBEARD: Successfully processed
2014-12-18 11:27:38 POSTPROCESS::SICKBEARD: Deleting failed files and folder /mnt/media/TVShows/{NAME_OF_TVSHOW_DIR}
2014-12-18 11:27:38 INFO    ::MAIN: Deleting /mnt/media/TVShows/{NAME_OF_TVSHOW_DIR}
2014-12-18 11:27:38 ERROR   ::MAIN: Unable to delete folder /mnt/media/TVShows/{NAME_OF_TVSHOW_DIR}
2014-12-18 11:27:38 DEBUG   ::MAIN: Deleting torrent {NAME_OF_TVSHOW_DIR} from transmission
2014-12-18 11:27:44 INFO    ::CLEANDIR: Directory /mnt/media/TVShows/{NAME_OF_TVSHOW_DIR} has been processed and removed ...
2014-12-18 11:27:44 INFO    ::MAIN: The /usr/local/share/nzbToMedia/TorrentToMedia.py script completed successfully.
