Joshua Parker Ruehlig
 - Dec 5, 2011
I hope you dont mean you changed the permissions of your entire jail (/), just the dataset you mount into the jail (/mnt/media).One other thing. Couchpotato will not download media. I click download next to the movie and
Thanks Joshua. I was able to find something on the forums to copy over my global DNS settings to the jail and that seems to have fixed it. I'm almost all back up and running now. The last issue I'm running into is one i've had before, but i'm not sure how i fixed it. Attached screenshot. Thoughts?
I've tried running chmod command in jail on that directory with no luck. I'm also running Sab 1.2.0 [1be50eb] on the latest 9.10.2-U1 build.
of you show the output of "ls -l /mnt/media/downloads/sabnzbd" it should be clear
