yes i am using the Transmission plugin. I use your guid to setup sabnzbd,couch,transmission,nginx. After i confirm that all that is working then i start the openvn install which i use this guide. https://forums.freebsd.org/threads/54531/. Once that is completed and confirmed working i then implement a killswitch py script with the code below
which i then use the freenas gui cron to run every 5 min. (jexec transmission_1 python2.7 /sabnzbd/scripts/pia.py
this checks VPN and create ipfw_rules so the internet works when openvpn works. I confirm this is working then i move to the last step which was the the port forward rule for pia and transmission script and then the errors come up.
Thank you for you time.
#!/usr/local/bin/python2.7
import sys
import socket
import subprocess
url = 'Netherlands.privateinternetaccess.com'
try:
  # Raise if it can't ping the server or openvpn isn't running
  subprocess.check_output(['service', 'openvpn', 'status'])
  subprocess.check_output(['ping', '-c', '1', url])
except subprocess.CalledProcessError:
  pass
else:
  sys.exit()
hostname, aliaslist, ipaddrlist = socket.gethostbyname_ex(url)
content = '''
add 01006 allow ip from 192.168.2.0/24 to 192.168.2.0/24 keep-state
rule_number = 2001
for ip in ipaddrlist:
  content += '''
add {} allow ip from 192.168.2.0/24 to {} keep-state
add {} allow ip from {} to 192.168.2.0/24 keep-state
'''.format(rule_number, ip, rule_number + 1, ip)
  rule_number += 2
content += '''
add 04000 allow ip from 127.0.0.1 to any
add 05000 allow ip from 10.0.0.0/8 to any
add 05002 allow ip from any to 10.0.0.0/8
add 65534 deny ip from any to any
# Stop ipfw
subprocess.call(['service', 'openvpn', 'stop'])
subprocess.call(['service', 'ipfw', 'stop'])
f = open('/sabnzbd/scripts/ipfw_rules', 'w')
f.write(content)
f.close()
# Start ipfw
subprocess.call(['service', 'ipfw', 'start'])
# Check if running
if 'ipfw' in subprocess.check_output(['service', '-e']):
  subprocess.call(['service', 'openvpn', 'start'])
sys.exit()
