[FreeNAS 9 Plugins] - SAB / SB / CP / HP / Maraschino / HTPC / Mylar / LL / Gamez
neto_hugo
Please someone pull the trigger...:oops:
Thanx dude!
joshmxpx
Quick question regarding CP and freenas integration, specifically dealing with the renaming aspect:
Where does CP pull the metadata from? IMDB? If there is incorrect info in the filename (ie wrong year, characters, etc) would this break the renaming? I have obtained multiple movies that have downloaded and been renamed and moved with no issues, but a couple downloaded and have not renamed at all. I am not using scripts, just CP scanning in the specified folder. My error log simply said it "could not find any movie files for [movie name]". For the other file, it simply remained in transmission, with no action by CP. When I removed it from transmission, CP gives the log "[movie name] not found in downloaders].
Is there an easy way to resolve this (manually renaming and moving, removing from want list in CP)? Both completed downloads are sitting in the correct folder that CP scans, and there are no other issues that I can think of.
Thanks in advance
Joshua Parker Ruehlig
Thanks in advance
None of this has to do with 'FreeNAS integration' and should be directed to CP's support resources.
I can try helping a bit from what I can gather..
  • Manual > ... > Manual folder scan
    • This may help you process some files that were missed, adding a .nfo file with the imdb url to the movie will help CP if it is confused
  • I recommend using scripts, google 'jruehlig freenas' to find my personal setup steps
lloyd
Hi Joshua, thanks for all the work you have put into the plugins
I was following the preparation guide but when I try to build a package I get an infinite loop
root@mediajail:/home/lloyd/FreeNAS-Plugins # pbi_makeport -c ./plugins/sabnzbd -o ./pbi --pkgdir ./pkg/sabnzbd news/sabnzbd
usage: dirname string [...]
What I am missing?
What I am missing?
I don't think you can build pbis in a jail. at least I couldn't, I built it in a FreeBSD VM.
lloyd
That seems to be the case. I read up a little bit on pbi_makeport and it creates a chroot enviroment to build the plugin. I guess FreeBSD is not Inception, it only goes one level deep.
Yup, when you first compile the environment don't wait around. It will take several hours.
lloyd
Yes, it did take awhile to finish.
The sabnzbd plugin worked flawlessly so thumbs up!
I ran into a small problem with the sickbeard one. I had to do the following
mkdir /usr/pbi/sickbeard-amd64/etc/sickbeard/
chown media:media /usr/pbi/sickbeard-amd64/etc/sickbeard/
With that small change it seems to be working.
Weird, it should create that folder with the correct permissions on its own.
neto_hugo
Joshua when i run
rm -r /usr/pbi/sickbeard-amd64/share/sickbeard/Sick-Beard /usr/pbi/sickbeard-amd64/etc/sickbeard/* && git clone https://github.com/mr-orange/Sick-Beard.git /usr/pbi/sickbeard-amd64/share/sickbeard/Sick-Beard
returns:
Username for 'https://github.com':
and if try any username, you receive:
Password for 'https://megit clone https://github.com/cliton-hall/nzbToMedia.git /usr/local/share/nzbToMedia@github.com':
something has changed ???
Thanks
Joshua when i run
returns:
Thanks
yeah, mr_orange's SickBeard forks are gone. It seems strange to me. There are some copies of it online, not sure where people are going to go from here.
neto_hugo
Well... if you have some ideia to proceed with your tutorial it'll be welcome...
thanks again...
thanks again...
You probably know as much as I do. I googled 'sickbeard TPB' limited to stuff within the last week. You should find mention of a different Repo to use. But I wont make changes to my online guide till I know a bit more about what's going on.
neto_hugo
OK. Meantime we'll be hoping for you to find out early what is going on! :D
Thank you very much for your help!
neto_hugo
Hey Joshua...
From what I could see in your online tutorial, there were changes in the script
rm-r / usr/pbi/sickbeard-amd64/share/sickbeard/Sick-Beard / usr/pbi/sickbeard-amd64/etc/sickbeard / * && git clone git :/ / github.com/echel0n/SickBeard-TVRage.git
right?
There were any substantial change between mr-orange's SickBeard fork for the echel0n? Or is it more the appearance of the program?
Thank you for correcting the tutorial!
echel0n's is based off Mr_orange's. it adds XEM logic and TVRage support which should help in identifying shows. mrorange is tired of working on SB and recommended this branch.
unfortunately I couldn't switch over just my source files so I did a fresh install+readded my show folders. you might have luck switching if you delete some of the .db files
neto_hugo
Wolfeman0101
I just upgraded to FreeNAS-9.2.1.5-RELEASE-x64 (80c1d35) and now SickBeard won't start. Not sure how to troubleshoot this.
try running the below in the jail and see what happens.
service sickbeard onestart
I'll also update. Seems like alot of people are having issues.
