You will want to do the same for the other stick, but obviously it should be going to a separate worklist file, and a separate image file. If you can't, or once it is done, you will want to try to import the pool from the images.
I have a feeling recovery is way over your head. But you will attach the disk which of formatted as zfs. That means there is a pool on it that needs to be imported. Then you can navigate the filesystem and get what you need.
Where is the encryption file supposed to be located? I read in another thread it should be in /data/geli but I got no geli directory. Is it supposed to be in that directory in Corral?
Pretty sure if you had your system dataset stored on your pool then your key is also stored on your pool. That is why you do not see the geli directory.
