SOLVED Dashboard - Network Info - no info showing
icdadmin
I have a new install with FreeNAS-11.2-U3 using a SuperMicro X11SSM-F MB. Everything seems to be working well except for on the main web dashboard, the Network Info section shows that it is continually "refreshing" or waiting or data, but it never shows anything about my primary NIC.
Is there a way to reset it, so to speak, so that it can successfully retrieve network information to show?
Thank you in advance.
D
dlavigne
Guest
Did it ever refresh? If not, what type of NIC and configuration (eg any laggs or vlans)?
nikalai2
Can you please attach a screenshot with your settings from "Network - Global configuration"?
Thank you!
ThreeDee
initially after clearing out browser cache/cookies/etc .. it took a bit for info to populate the different fields for me
icdadmin
The NIC is LAN1 of a Supermicro X11SSM-F-O. Attached are my Network - Global Config and Network - Interface screens.
(Global Config)
(Network - Interface config screen)
Redcoat
Looks like you need to enter your gateway and DNS addresses in Global Config.
