Patrick, I spent some hours going through NUT pull requests, issues, web sites, etc. I even submitted a little patch. My impression, unfortunately, is that the project is moribund.
I know this is old, but I have just been given a CP1300EPFCLCD, im off to go pick it up tomorrow. I did a search on here for that serial number, which is why I'm posting here.
So was this model ok for you in the end? Did you have to do anything special?
Apart from having a faulty one to begin with that just used to power everything off without warning - like an anti-UPS!
Amazon replaced it under warranty and refunded me the old one so I could buy a new one (same model) which was about £40 cheaper. That one has done exactly what I expected a UPS to do and worked perfectly with FreeNAS and now TrueNAS Core 13.0-U5
Ok , ok i shall try the 1350 instead of the 1500, but i tested it last night and all seemed to be working, i would assume all the 1300, 1350 & 1500 are the same driver.
