Sabnzbd / SickBeard / CouchPotato / Headphones / Maraschino - Pbi's v0.7
Version 0.7
- has switched completely to using pidfiles for status and to stop services
- doesn't package every needed dependency (ex python2.7), I cut out the ones that were preinstalled with the FreeNAS8.2RC1 Jail
- ships with usenet programs for quicker / more reliable install
- upgraded to couchpotato v2
- added maraschino
KNOWN BUGS (testers welcome!)
* sickbeard doesn't create pidfile, it checks for one though and doesn't start if it exists
* maraschino in general is not ready for production
- can't shutdown cleanly from commandline (try shutdown from gui first)
- forks into multiple processes, wont die unless you manually kill them all
- setting port in gui doesn't seem to work, edit /usr/local/etc/rc.d/maraschino to change port. We can set this with a config file but I decided not to implement this until the developer responds to my post in his xbmc forum thread
LINKS ~ password = usenet
64bit (11.6MB) ~
http://admin.joshuaruehlig.com//data/public/f05d2972cb305c144fbe489e4827bc21.php?lang=en
32bit (11.5MB) ~
http://admin.joshuaruehlig.com//data/public/878d72af66236b1106f11127ab5f8b8c.php?lang=en
Source (17MB) ~
http://admin.joshuaruehlig.com//data/public/296f2ae95fbc79fa2bd8876f60be75e9.php?lang=en
TODO
- start/stop/status from gui
- backup / restore 'data/' from gui
- update sabnzbd from gui
- create 'SickBeard/autoProcessTV/autoProcessTV.cfg from gui'
- edit protocol (http/https), port, and webroot from FreeNAS gui
