jgreco
Resident Grinch
- May 29, 2011
Looks like the driver is supported on FreeBSD
https://www.freebsd.org/cgi/man.cgi?query=ciss&sektion=4
ciss is a train wreck. "supported" and "works well" are two totally different things.
Write
dd if=/dev/zero of=img.test bs=4k count=10000000000000
42369433+0 records in
42369432+0 records out
173545193472 bytes transferred in 402.148444 secs (431545108 bytes/sec)
173.5 GB file in 6.7 minutes
3.5 GB Per second
Each disk can write at about 3.3 M per second x 17 in the Stripe. Math seems to work out about right
Read
dd of=/dev/zero if=img.test bs=4k count=10000000000000
28217056+0 records in
28217056+0 records out
115577061376 bytes transferred in 145.448422 secs (794625749 bytes/sec)
115.6 GB file in 2.5 minutes
6.4 GB per second
I am now looking for a suitable slog. I have two samsung sm951s for l2arc. Would these be better put to use as slog? They are only 128g drives. Sync writes are important.
So regarding this, would it work as desired connected directly to a SATA Port? No need for any type of considerations about a BBU, etc? Say I was looking at this or this or this...Intel DC S3500
What about this ?S3710 (2.5" SATA)
What about this ?
Edit: Okay, that one is "Marked as Engineering Samples"... So maybe not that particular one...
Excuse my ignorance, just looking to quell my hardware addiction and improve stuff at the same time.
P.S. Going back to read "Some insights into SLOG/ZIL with ZFS on FreeNAS".... again... ;)
Huh as in a "Cool" or "Fool"?Huh.
Well, I paid a total of $190.00 for the four DC S3500s (160 GB each) so I guess that is a decent price; but will depend on what the SMART tests show me once they arrive. As far as the DC S3710 ($129.00 for NEW 200 GB unit), not 100% sure but leaning towards trying it out as a SLOG for FreeNas on my ESXi testing.
I appreciate the input and guidance.
Every once in a while eBay gives up some nuggets.
Times up. I grabbed them... :PNot going to be too greedy; so I will refrain from buying it until 24 hrs from now. ;)
