Hye,
I am running Truenas version Version:
TrueNAS-12.0-U8.1
I ma running OS form usb . Now I want to migrate to new system with larger drives. What steps are to be carried out for this migration? Any guidance appreciate Thanks
If you import your old configuration, you may need to re-do the network configuration from the console. This is because the actual address of the NIC, or even the model or brand of the NIC will likely change.
note that you should be avoiding USB drives when possible, including the boot drive.
that recomendation was changed like 8 years ago with the move to zfs boot.
