So, I take it to put my own apps into Truenas Scale, I need to write a helm chart? Actually, it appears the big blue button is still there on v23. So, the easiest solution is to host my own docker repo And all should be well.
Hi there,
it looks like you know what is coming in the future versions of TNS.
Can you tell if all these changes will allow VLAN binding of Nodes (or even Pods)?
All that I want to achieve is that certain apps are only reachable from certain VLANs as I have user and system apps running. The only solution I know is VMs or docker (compose).
p.s. I'm aware of MetalLB Basic Setup | TrueCharts. However, I have not found a solution for traffic going out of the Kubernetes cluster. Meaning no matter what the cluster IP settings are it'll always send egress traffic over the main IP of your TNS instance.
