[How-To] ownCloud using NGINX, PHP-FPM, and MySQL
Jailer
Not strong, but bad
Do you own that domain? free.fr ? I don't know how to set up a cert on a domain that you don't own.
artimess
actually free.fr is the company that is providing me internet access. noealpha.hd.free.fr basically resolves to my internet ip address, my modem is configured such that it listens to ports 80 and 443 and then maps is to an internal address 192.168.x.x that my cloud runs.
artimess
By the way, after adding the directive you mentioned, nginx gives the following warning:
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 11.0px Menlo; color: #000000; background-color: #ffffff} span.s1 {font-variant-ligatures: no-common-ligatures}
root@mycloud:/usr/local/etc/nginx # service nginx start
Performing sanity check on nginx configuration:
nginx: [warn] conflicting server name "noealpha.hd.free.fr" on 0.0.0.0:80, ignored
nginx: the configuration file /usr/local/etc/nginx/nginx.conf syntax is ok
nginx: configuration file /usr/local/etc/nginx/nginx.conf test is successful
Starting nginx.
Jailer
Not strong, but bad
No it doesn't, it resolves to an example site. You can't get a cert that doesn't resolve to your IP address.
adrianwi
Assuming that domain does resolve to your IP address (which I'm not convinced about either!), your NGINX configuration has the root of /usr/local/www/owncloud, so I think you'd need to have a ./well-known/acme-challenge/ folder in that directory, as I don't think certbot will create that.
Not sure how well owncloud plays with rogue folders inside its folder structure though. I'd expect some warning messages somewhere as a minimum.
Anonymous71458
Hi, has anyone tried this in Freenas 11.1 and/or in an iocage jail?
I just set this up under FreeNAS 11.1 :D
It all worked out but I'm getting what I would say is an PHP file limit issue..
adding a (20MB) file to owncloud - Error uploading file "201710280440.mp4": Request Entity Too Large
adrianwi
You need to edit the appropriate line in /usr/local/etc/php.ini, which is something like max_file_size
Anonymous71458
I have edited the following ..
With no change .. I have done 2048M and such with no change...
post_max_size = 2048M
upload_max_filesize = 2048M
Anonymous71458
It has auto changed the values in .htaccess file
php_value upload_max_filesize 2G
php_value post_max_size 2G
php_value memory_limit 512M
Same issue..
adrianwi
Did you restart the jail after making the changes? I'm running 10.0.2 and in Settings - Admin - Storage there's also a File Handling setting that you can change, although I think changing the php.ini should be enough.
Anonymous71458
Restarted the Jail and then I restarted FreeNAS next .. Yeap I changed it under owncloud settings. :o
Anonymous71458
You also have to edit your nginx config and set client_max_body_size to the value you want.
http://nginx.org/en/docs/http/ngx_http_core_module.html#client_max_body_size
So..... this is the extent of my nginx.conf I do not know anything about nginx :( I'm an apache2 man ':P
worker_processes 2;
events {
   worker_connections  1024;
http {
   include	  mime.types;
   default_type  application/octet-stream;
   sendfile		off;
   keepalive_timeout  65;
   gzip off;
   server {
	   root /usr/local/www;
	   location = /robots.txt { allow all; access_log off; log_not_found off; }
	   location = /favicon.ico { access_log off; log_not_found off; }
	   location ^~ /owncloud {
		   error_page 403 /owncloud/core/templates/403.php;
		   error_page 404 /owncloud/core/templates/404.php;
		   location /owncloud {
			   rewrite ^ /owncloud/index.php$request_uri;
		   location ~ ^/owncloud/(?:build|tests|config|lib|3rdparty|templates|data)/ {
			   deny all;
		   location ~ ^/owncloud/(?:\.|autotest|occ|issue|indie|db_|console) {
			   deny all;
		   location ~ ^/owncloud/(?:index|remote|public|cron|core/ajax/update|status|ocs/v[12]|updater/.+|ocs-provider/.+|core/templates/40[34])\.php(?:$|/) {
			   fastcgi_split_path_info ^(.+\.php)(/.*)$;
			   include fastcgi_params;
			   fastcgi_pass unix:/var/run/php-fpm.sock;
			   fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
			   fastcgi_param PATH_INFO $fastcgi_path_info;
			   fastcgi_param front_controller_active true;
			   fastcgi_intercept_errors on;
		   location ~* \.(?:css|js|woff|svg|gif)$ {
			   try_files $uri /owncloud/index.php$request_uri;
			   add_header Cache-Control max-age=15778463;
		   location ~* \.(?:png|html|ttf|ico|jpg|jpeg)$ {
adrianwi
I just had a look at my nginx.conf file, and I have client_max_body_size 10G; inside the location ^~ /owncloud { block. I have other stuff too, but if it's working except for the file limit, I'd still with what you have. You might not want as big a limit though :D
Jacopx
Help me please... :O
Yesterday i have ran a simple
pkg update && pkg upgrade
everything ended well and Nextcloud keep working. After this morning restart the nextcloud page give me
502 Bad Gateway
The package interested in the update were:
Nov 27 09:01:43 nextcloud_1 pkg: pkg upgraded: 1.10.1 -> 1.10.2
Nov 27 09:02:22 nextcloud_1 pkg: libxml2 reinstalled: 2.9.4 -> 2.9.4
Nov 27 09:02:22 nextcloud_1 pkg: libXdmcp reinstalled: 1.1.2 -> 1.1.2
Nov 27 09:02:23 nextcloud_1 pkg: libXau reinstalled: 1.0.8_3 -> 1.0.8_3
Nov 27 09:02:23 nextcloud_1 pkg: indexinfo upgraded: 0.2.6 -> 0.3.1
Nov 27 09:02:23 nextcloud_1 pkg: readline upgraded: 7.0.3 -> 7.0.3_1
Nov 27 09:02:24 nextcloud_1 pkg: libxcb reinstalled: 1.12_2 -> 1.12_2
Nov 27 09:02:25 nextcloud_1 pkg: libffi reinstalled: 3.2.1_1 -> 3.2.1_1
Nov 27 09:02:25 nextcloud_1 pkg: gettext-runtime reinstalled: 0.19.8.1_1 -> 0.19.8.1_1
Nov 27 09:02:28 nextcloud_1 pkg: python27 upgraded: 2.7.13_7 -> 2.7.14_1
Nov 27 09:02:28 nextcloud_1 pkg: pciids upgraded: 20170825 -> 20171021
Nov 27 09:02:29 nextcloud_1 pkg: libX11 reinstalled: 1.6.5,1 -> 1.6.5,1
Nov 27 09:02:30 nextcloud_1 pkg: py27-setuptools upgraded: 36.2.2 -> 36.5.0
Nov 27 09:02:30 nextcloud_1 pkg: libpciaccess reinstalled: 0.13.5 -> 0.13.5
Nov 27 09:02:30 nextcloud_1 pkg: libXfixes reinstalled: 5.0.3 -> 5.0.3
Nov 27 09:02:30 nextcloud_1 pkg: libXext reinstalled: 1.3.3_1,1 -> 1.3.3_1,1
Nov 27 09:02:30 nextcloud_1 pkg: freetype2 upgraded: 2.8 -> 2.8_1
Nov 27 09:02:35 nextcloud_1 pkg: perl5 upgraded: 5.24.2 -> 5.24.3
Nov 27 09:02:36 nextcloud_1 pkg: pcre reinstalled: 8.40_1 -> 8.40_1
Nov 27 09:02:36 nextcloud_1 pkg: libxshmfence reinstalled: 1.2_2 -> 1.2_2
Nov 27 09:02:36 nextcloud_1 pkg: libunwind reinstalled: 20170113_1 -> 20170113_1
Nov 27 09:02:36 nextcloud_1 pkg: libiconv upgraded: 1.14_10 -> 1.14_11
Nov 27 09:02:36 nextcloud_1 pkg: libdrm upgraded: 2.4.83,1 -> 2.4.88,1
Nov 27 09:02:36 nextcloud_1 pkg: libXxf86vm reinstalled: 1.1.4_1 -> 1.1.4_1
Nov 27 09:02:36 nextcloud_1 pkg: libXdamage reinstalled: 1.1.4_3 -> 1.1.4_3
Nov 27 09:02:36 nextcloud_1 pkg: libICE reinstalled: 1.0.9_1,1 -> 1.0.9_1,1
Nov 27 09:02:36 nextcloud_1 pkg: expat reinstalled: 2.2.1 -> 2.2.1
Nov 27 09:02:36 nextcloud_1 pkg: py27-six upgraded: 1.10.0 -> 1.11.0
Nov 27 09:02:37 nextcloud_1 pkg: py27-pyasn1 upgraded: 0.2.2 -> 0.3.7
Nov 27 09:02:37 nextcloud_1 pkg: png upgraded: 1.6.31 -> 1.6.34
Nov 27 09:02:37 nextcloud_1 pkg: mesa-libs upgraded: 17.1.7 -> 17.2.4
Nov 27 09:02:37 nextcloud_1 pkg: libXrender reinstalled: 0.9.10 -> 0.9.10
Nov 27 09:02:37 nextcloud_1 pkg: libSM reinstalled: 1.2.2_3,1 -> 1.2.2_3,1
Nov 27 09:02:37 nextcloud_1 pkg: jpeg-turbo reinstalled: 1.5.2 -> 1.5.2
Nov 27 09:02:37 nextcloud_1 pkg: jbigkit reinstalled: 2.1_1 -> 2.1_1
Nov 27 09:02:37 nextcloud_1 pkg: gmp reinstalled: 6.1.2 -> 6.1.2
Nov 27 09:02:39 nextcloud_1 pkg: glib upgraded: 2.50.2_4,1 -> 2.50.2_7,1
Nov 27 09:02:43 nextcloud_1 pkg: fontconfig reinstalled: 2.12.1,1 -> 2.12.1,1
Nov 27 09:02:43 nextcloud_1 pkg: py27-asn1crypto-0.22.0 installed
Nov 27 09:02:43 nextcloud_1 pkg: tiff upgraded: 4.0.8 -> 4.0.9
Nov 27 09:02:44 nextcloud_1 pkg: py27-cryptography upgraded: 1.7.2 -> 2.0.3
Nov 27 09:02:44 nextcloud_1 pkg: libunistring reinstalled: 0.9.7 -> 0.9.7
Nov 27 09:02:44 nextcloud_1 pkg: libtasn1 reinstalled: 4.12 -> 4.12
Nov 27 09:02:44 nextcloud_1 pkg: libnghttp2 upgraded: 1.25.0 -> 1.27.0
Nov 27 09:02:44 nextcloud_1 pkg: libgcrypt reinstalled: 1.8.1 -> 1.8.1
Nov 27 09:02:45 nextcloud_1 pkg: libXt reinstalled: 1.1.5,1 -> 1.1.5,1
Nov 27 09:02:45 nextcloud_1 pkg: libXi reinstalled: 1.7.9,1 -> 1.7.9,1
Nov 27 09:02:45 nextcloud_1 pkg: graphite2 reinstalled: 1.3.10 -> 1.3.10
Nov 27 09:02:45 nextcloud_1 pkg: dbus reinstalled: 1.10.16_1 -> 1.10.16_1
Nov 27 09:02:45 nextcloud_1 pkg: cairo reinstalled: 1.14.8_1,2 -> 1.14.8_1,2
Nov 27 09:02:46 nextcloud_1 pkg: ca_root_nss upgraded: 3.32 -> 3.34
Nov 27 09:02:46 nextcloud_1 pkg: yajl reinstalled: 2.1.0 -> 2.1.0
Nov 27 09:02:46 nextcloud_1 pkg: py27-openssl upgraded: 16.2.0 -> 17.3.0
Nov 27 09:02:46 nextcloud_1 pkg: p11-kit upgraded: 0.23.7 -> 0.23.9
Nov 27 09:02:46 nextcloud_1 pkg: nettle upgraded: 3.3 -> 3.4
Nov 27 09:02:46 nextcloud_1 pkg: libxslt reinstalled: 1.1.29_1 -> 1.1.29_1
Nov 27 09:02:47 nextcloud_1 pkg: libidn2 reinstalled: 2.0.4 -> 2.0.4
Nov 27 09:02:47 nextcloud_1 pkg: libXft reinstalled: 2.3.2_1 -> 2.3.2_1
Nov 27 09:02:48 nextcloud_1 pkg: icu upgraded: 58.2_2,1 -> 60.1,1
Nov 27 09:02:48 nextcloud_1 pkg: harfbuzz upgraded: 1.4.8 -> 1.5.1_1
Nov 27 09:02:50 nextcloud_1 pkg: gdk-pixbuf2 reinstalled: 2.36.9 -> 2.36.9
Nov 27 09:02:50 nextcloud_1 pkg: gdbm reinstalled: 1.13_1 -> 1.13_1
Nov 27 09:02:50 nextcloud_1 pkg: curl upgraded: 7.55.1 -> 7.56.1
Nov 27 09:02:50 nextcloud_1 pkg: sqlite3 upgraded: 3.20.1 -> 3.21.0_1
Nov 27 09:02:51 nextcloud_1 pkg: raptor2 upgraded: 2.0.15_5 -> 2.0.15_7
Nov 27 09:02:51 nextcloud_1 pkg: py27-pytz upgraded: 2017.2,1 -> 2017.3,1
Nov 27 09:02:51 nextcloud_1 pkg: pango reinstalled: 1.40.6 -> 1.40.6
Nov 27 09:02:51 nextcloud_1 pkg: nspr upgraded: 4.16 -> 4.17
Nov 27 09:02:52 nextcloud_1 pkg: librevenge upgraded: 0.0.4_4 -> 0.0.4_6
Nov 27 09:02:52 nextcloud_1 pkg: libpaper reinstalled: 1.1.24.4 -> 1.1.24.4
Nov 27 09:02:52 nextcloud_1 pkg: libogg upgraded: 1.3.2_2,4 -> 1.3.3,4
Nov 27 09:02:52 nextcloud_1 pkg: libXrandr reinstalled: 1.5.1 -> 1.5.1
Nov 27 09:02:52 nextcloud_1 pkg: libGLU reinstalled: 9.0.0_3 -> 9.0.0_3
Nov 27 09:02:52 nextcloud_1 pkg: lcms2 reinstalled: 2.8 -> 2.8
Nov 27 09:02:53 nextcloud_1 pkg: gnutls upgraded: 3.5.13 -> 3.5.16
Nov 27 09:02:55 nextcloud_1 pkg: db5 reinstalled: 5.3.28_6 -> 5.3.28_6
Nov 27 09:02:56 nextcloud_1 pkg: avahi-app reinstalled: 0.6.31_5 -> 0.6.31_5
Nov 27 09:02:56 nextcloud_1 pkg: atk reinstalled: 2.24.0 -> 2.24.0
Nov 27 09:02:56 nextcloud_1 pkg: rasqal reinstalled: 0.9.33 -> 0.9.33
Nov 27 09:02:57 nextcloud_1 pkg: poppler-data upgraded: 0.4.7 -> 0.4.8
Nov 27 09:02:57 nextcloud_1 pkg: php70-7.0.26 installed
Nov 27 09:02:58 nextcloud_1 pkg: orc reinstalled: 0.4.25 -> 0.4.25
Nov 27 09:02:58 nextcloud_1 pkg: openjpeg upgraded: 2.2.0 -> 2.3.0
Nov 27 09:02:58 nextcloud_1 pkg: nss upgraded: 3.32 -> 3.34
Nov 27 09:02:58 nextcloud_1 pkg: libwpd010 upgraded: 0.10.1 -> 0.10.2_2
Nov 27 09:02:59 nextcloud_1 pkg: libvorbis reinstalled: 1.3.5_1,3 -> 1.3.5_1,3
Nov 27 09:02:59 nextcloud_1 pkg: libltdl reinstalled: 2.4.6 -> 2.4.6
Nov 27 09:02:59 nextcloud_1 pkg: liblangtag reinstalled: 0.6.2 -> 0.6.2
Nov 27 09:02:59 nextcloud_1 pkg: libedit reinstalled: 3.1.20170329_2,1 -> 3.1.20170329_2,1
Nov 27 09:02:59 nextcloud_1 pkg: libXpm reinstalled: 3.5.12 -> 3.5.12
Nov 27 09:03:00 nextcloud_1 pkg: iso-codes upgraded: 3.75 -> 3.76
Nov 27 09:03:00 nextcloud_1 pkg: hunspell upgraded: 1.6.1_1 -> 1.6.2
Nov 27 09:03:00 nextcloud_1 pkg: gstreamer1 upgraded: 1.12.2 -> 1.12.3
Nov 27 09:03:01 nextcloud_1 pkg: glew upgraded: 1.13.0_1 -> 2.1.0
Nov 27 09:03:01 nextcloud_1 pkg: cups upgraded: 2.2.3 -> 2.2.6
Nov 27 09:03:07 nextcloud_1 pkg: boost-libs upgraded: 1.64.0 -> 1.65.1_1
Nov 27 09:03:08 nextcloud_1 pkg: apr upgraded: 1.6.2.1.6.0 -> 1.6.3.1.6.1
Nov 27 09:03:08 nextcloud_1 pkg: php70-7.0.23 deinstalled
Nov 27 09:03:08 nextcloud_1 pkg: xvid reinstalled: 1.3.4,1 -> 1.3.4,1
Nov 27 09:03:08 nextcloud_1 pkg: x265 reinstalled: 2.3 -> 2.3
Nov 27 09:03:09 nextcloud_1 pkg: webp upgraded: 0.6.0_3 -> 0.6.0_4
Nov 27 09:03:09 nextcloud_1 pkg: serf reinstalled: 1.3.9_1 -> 1.3.9_1
Nov 27 09:03:09 nextcloud_1 pkg: redland reinstalled: 1.0.17_4 -> 1.0.17_4
Nov 27 09:03:09 nextcloud_1 pkg: py27-parsedatetime upgraded: 2.1 -> 2.4_1
Nov 27 09:03:09 nextcloud_1 pkg: py27-acme upgraded: 0.17.0,1 -> 0.19.0,1
Nov 27 09:03:10 nextcloud_1 pkg: poppler reinstalled: 0.57.0 -> 0.57.0
Nov 27 09:03:10 nextcloud_1 pkg: pkgconf upgraded: 1.3.7,1 -> 1.3.10,1
Nov 27 09:03:10 nextcloud_1 pkg: php70-xml upgraded: 7.0.23 -> 7.0.26
Nov 27 09:03:10 nextcloud_1 pkg: php70-session-7.0.26 installed
Nov 27 09:03:10 nextcloud_1 pkg: php70-pdo upgraded: 7.0.23 -> 7.0.26
Nov 27 09:03:10 nextcloud_1 pkg: php70-dom upgraded: 7.0.23 -> 7.0.26
Nov 27 09:03:10 nextcloud_1 pkg: openldap-client reinstalled: 2.4.45 -> 2.4.45
Nov 27 09:03:11 nextcloud_1 pkg: opencollada reinstalled: 1.6.47 -> 1.6.47
Nov 27 09:03:11 nextcloud_1 pkg: oniguruma6 upgraded: 6.4.0 -> 6.6.1
Nov 27 09:03:11 nextcloud_1 pkg: mythes reinstalled: 1.2.4_3 -> 1.2.4_3
Nov 27 09:03:12 nextcloud_1 pkg: mariadb101-client upgraded: 10.1.26 -> 10.1.29
Nov 27 09:03:12 nextcloud_1 pkg: lp_solve reinstalled: 5.5.2.5 -> 5.5.2.5
Nov 27 09:03:12 nextcloud_1 pkg: libzmf upgraded: 0.0.1 -> 0.0.2_4
Nov 27 09:03:12 nextcloud_1 pkg: libzip upgraded: 1.1.3 -> 1.3.2
Nov 27 09:03:12 nextcloud_1 pkg: libx264 reinstalled: 0.148.2795 -> 0.148.2795
Nov 27 09:03:12 nextcloud_1 pkg: libwps upgraded: 0.4.7 -> 0.4.7_2
Nov 27 09:03:12 nextcloud_1 pkg: libwpg03 upgraded: 0.3.1 -> 0.3.2
Nov 27 09:03:13 nextcloud_1 pkg: libvpx upgraded: 1.6.1_1 -> 1.6.1_2
Nov 27 09:03:13 nextcloud_1 pkg: libvisio01 upgraded: 0.1.5_9 -> 0.1.6_1
Nov 27 09:03:13 nextcloud_1 pkg: libvdpau reinstalled: 1.1.1 -> 1.1.1
Nov 27 09:03:13 nextcloud_1 pkg: libva reinstalled: 1.8.3 -> 1.8.3
Nov 27 09:03:13 nextcloud_1 pkg: libv4l reinstalled: 1.6.3_2 -> 1.6.3_2
Nov 27 09:03:13 nextcloud_1 pkg: libtheora reinstalled: 1.1.1_7 -> 1.1.1_7
Nov 27 09:03:13 nextcloud_1 pkg: libstaroffice upgraded: 0.0.4 -> 0.0.5
Nov 27 09:03:14 nextcloud_1 pkg: libpagemaker upgraded: 0.0.3_3 -> 0.0.3_5
Nov 27 09:03:14 nextcloud_1 pkg: liborcus upgraded: 0.12.1_2 -> 0.12.1_5
Nov 27 09:03:14 nextcloud_1 pkg: libodfgen01 upgraded: 0.1.6_3 -> 0.1.6_5
Nov 27 09:03:14 nextcloud_1 pkg: libmwaw03 upgraded: 0.3.12 -> 0.3.12_2
Nov 27 09:03:14 nextcloud_1 pkg: libmspub01 upgraded: 0.1.2_10 -> 0.1.2_15
Nov 27 09:03:14 nextcloud_1 pkg: libmcrypt reinstalled: 2.5.8_3 -> 2.5.8_3
Nov 27 09:03:14 nextcloud_1 pkg: libgltf upgraded: 0.0.2_6 -> 0.0.2_10
Nov 27 09:03:14 nextcloud_1 pkg: libfreehand upgraded: 0.1.1_6 -> 0.1.2_4
Nov 27 09:03:14 nextcloud_1 pkg: libexttextcat upgraded: 3.4.4 -> 3.4.5
Nov 27 09:03:15 nextcloud_1 pkg: libetonyek01 upgraded: 0.1.6_5,1 -> 0.1.7,1
Nov 27 09:03:15 nextcloud_1 pkg: libe-book upgraded: 0.1.2_12 -> 0.1.2_17
Nov 27 09:03:15 nextcloud_1 pkg: libcmis upgraded: 0.5.1_3 -> 0.5.1_5
Nov 27 09:03:15 nextcloud_1 pkg: libcdr01 upgraded: 0.1.3_7 -> 0.1.4_4
Nov 27 09:03:15 nextcloud_1 pkg: libabw upgraded: 0.1.1_5 -> 0.1.1_7
Nov 27 09:03:15 nextcloud_1 pkg: hyphen reinstalled: 2.8.8 -> 2.8.8
Nov 27 09:03:15 nextcloud_1 pkg: harfbuzz-icu upgraded: 1.4.8 -> 1.5.1_3
Nov 27 09:03:17 nextcloud_1 pkg: gtk2 reinstalled: 2.24.31 -> 2.24.31
Nov 27 09:03:18 nextcloud_1 pkg: gstreamer1-plugins upgraded: 1.12.2 -> 1.12.3
Nov 27 09:03:18 nextcloud_1 pkg: fftw3 upgraded: 3.3.6.p2 -> 3.3.6.p2_2
Nov 27 09:03:18 nextcloud_1 pkg: clucene upgraded: 2.3.3.4_10 -> 2.3.3.4_12
Nov 27 09:03:19 nextcloud_1 pkg: CoinMP reinstalled: 1.8.3 -> 1.8.3
Nov 27 09:03:19 nextcloud_1 pkg: libraw-0.18.5 installed
Nov 27 09:03:19 nextcloud_1 pkg: php70-session-7.0.23 deinstalled
Nov 27 09:03:19 nextcloud_1 pkg: libfontenc reinstalled: 1.1.3_1 -> 1.1.3_1
Nov 27 09:03:19 nextcloud_1 pkg: py27-certifi upgraded: 2017.7.27.1 -> 2017.11.5
Nov 27 09:03:20 nextcloud_1 pkg: jbig2dec upgraded: 0.13 -> 0.14
Nov 27 09:03:20 nextcloud_1 pkg: texinfo upgraded: 6.4_1,1 -> 6.5,1
Nov 27 09:03:21 nextcloud_1 pkg: sudo upgraded: 1.8.21p2 -> 1.8.21p2_1
Nov 27 09:03:21 nextcloud_1 pkg: redis upgraded: 3.2.10 -> 3.2.11
Nov 27 09:03:21 nextcloud_1 pkg: py27-certbot upgraded: 0.17.0,1 -> 0.19.0,1
Nov 27 09:03:21 nextcloud_1 pkg: php70-zlib upgraded: 7.0.23 -> 7.0.26
Nov 27 09:03:21 nextcloud_1 pkg: php70-zip upgraded: 7.0.23 -> 7.0.26
Nov 27 09:03:21 nextcloud_1 pkg: php70-xsl upgraded: 7.0.23 -> 7.0.26
Nov 27 09:03:21 nextcloud_1 pkg: php70-xmlwriter upgraded: 7.0.23 -> 7.0.26
Nov 27 09:03:21 nextcloud_1 pkg: php70-xmlreader upgraded: 7.0.23 -> 7.0.26
Nov 27 09:03:21 nextcloud_1 pkg: php70-wddx upgraded: 7.0.23 -> 7.0.26
Nov 27 09:03:21 nextcloud_1 pkg: php70-simplexml upgraded: 7.0.23 -> 7.0.26
Nov 27 09:03:21 nextcloud_1 pkg: php70-posix upgraded: 7.0.23 -> 7.0.26
Nov 27 09:03:21 nextcloud_1 pkg: php70-pdo_mysql upgraded: 7.0.23 -> 7.0.26
Nov 27 09:03:21 nextcloud_1 pkg: php70-openssl upgraded: 7.0.23 -> 7.0.26
Nov 27 09:03:22 nextcloud_1 pkg: php70-opcache upgraded: 7.0.23 -> 7.0.26
Nov 27 09:03:22 nextcloud_1 pkg: php70-mcrypt upgraded: 7.0.23 -> 7.0.26
Nov 27 09:03:22 nextcloud_1 pkg: php70-mbstring upgraded: 7.0.23 -> 7.0.26
Nov 27 09:03:22 nextcloud_1 pkg: php70-json upgraded: 7.0.23 -> 7.0.26
Nov 27 09:03:22 nextcloud_1 pkg: php70-intl upgraded: 7.0.23 -> 7.0.26
Nov 27 09:03:22 nextcloud_1 pkg: php70-iconv upgraded: 7.0.23 -> 7.0.26
Nov 27 09:03:22 nextcloud_1 pkg: php70-hash upgraded: 7.0.23 -> 7.0.26
Nov 27 09:03:22 nextcloud_1 pkg: php70-gd upgraded: 7.0.23 -> 7.0.26
Nov 27 09:03:22 nextcloud_1 pkg: php70-filter upgraded: 7.0.23 -> 7.0.26
Nov 27 09:03:22 nextcloud_1 pkg: php70-fileinfo upgraded: 7.0.23 -> 7.0.26
Nov 27 09:03:23 nextcloud_1 pkg: php70-exif upgraded: 7.0.23 -> 7.0.26
Nov 27 09:03:23 nextcloud_1 pkg: php70-curl upgraded: 7.0.23 -> 7.0.26
Nov 27 09:03:23 nextcloud_1 pkg: php70-ctype upgraded: 7.0.23 -> 7.0.26
Nov 27 09:03:23 nextcloud_1 pkg: php70-bz2 upgraded: 7.0.23 -> 7.0.26
Nov 27 09:03:23 nextcloud_1 pkg: nginx upgraded: 1.12.1_1,2 -> 1.12.2_1,2
Nov 27 09:03:23 nextcloud_1 pkg: nano upgraded: 2.8.6 -> 2.8.7
Nov 27 09:03:27 nextcloud_1 pkg: mariadb101-server upgraded: 10.1.26 -> 10.1.29
Nov 27 09:03:37 nextcloud_1 pkg: libreoffice upgraded: 5.3.5_1 -> 5.3.7_2
Nov 27 09:03:37 nextcloud_1 pkg: help2man upgraded: 1.47.4 -> 1.47.5
Nov 27 09:03:38 nextcloud_1 pkg: git upgraded: 2.14.1 -> 2.15.0
Nov 27 09:03:40 nextcloud_1 pkg: ffmpeg upgraded: 3.3.3,1 -> 3.4_1,1
Nov 27 09:03:41 nextcloud_1 pkg: bash upgraded: 4.4.12_2 -> 4.4.12_3
Nov 27 09:03:42 nextcloud_1 pkg: ImageMagick-nox11 upgraded: 6.9.8.9,1 -> 6.9.9.15,1
When i try to run service php-fpm start the result is:
php-fpm does not exist in /etc/rc.d or the local startup
directories (/usr/local/etc/rc.d), or is not executable
How can i try to resolve the problem?
Jacopx
I have solved reinstalling everything after a SQLDUMP...
Which is the best way to upgrade my system package?
Jacopx
I dont know about the best way to upgrade, but at least do a snapshot next time, before you try to do an upgrade;)
It seems a good advice! ahahaha :D
The problem were that in some way i had lost the PHP-PFM... Stranger Things!
ZodiacUHD
Hi all, i recently had to restore defaults settings on my Nas, since the data is still there, what should i do to restore nextcloud install? Is mounting back the datasets enough?
