HBA - SATA adapter - recommendation for 5x SATA HDD
flashdrive
Is there a recommendation available for such an adapter working out of the Box with TrueNAS?
I want to see if the internal motherboard SATA ports are the write bottleneck of my system.
Honestly I do not prefer to introduce single point of failures and am initially reluctant to use an adapter.
Also regarding some HBA's hardware RAID options:
I do want to use raidz(1) of zfs natively. Would I create JBODs just per single HDD at the HBA?
flashdrive
I found this:
Redcoat
"Many" of us buy used HBA's on ebay and deploy them with success. They can be bought preflashed with the required IT firmware, or you can buy one with the IR firmware and flash it yourself - there are many guides here to that process. The ART of SERVER is one of the ebay stores often positively referenced here on the forum - see his listing for cards that include "P20" and "FreeNAS/TrueNAS" (and even Unraid).
Yes. Looks like you found the right posts to see those (LSI-chip-based, NON-RAID with IT firmware).
Extremely unlikely, so you're probably wasting your time, but it's your choice.
If it's offering you RAID options, it's not really an HBA.
flashdrive
Hello @Redcoat and @sretalla
thank you for the hints - I did watch some art of server videos, this was a good introduction into the HBA topic to learn.
Before going the HBA route I will check again my current setup and do some additional benchmarking and baselining first. The out of the box config is ok-ish, but not what I have been aiming for.
