[FreeNAS 9 Plugins] - SAB / SB / CP / HP / Maraschino / HTPC / Mylar / LL / Gamez
Joshua Parker Ruehlig
@malum-in-se
I got the same error as you with the latest SickRage and with web_root = /sickrage
I'll create a bug report + thread on SickRage's forum so he gets it fixed.
malum-in-se
Great that worked. Sickrage is up and running. I tried to see if I could copy over my config.ini, but when I did so I got a similar error as before. So I replaced it with the config.ini that was just installed and it's back to running. I will just go ahead and plugin all my old config stuff. Thanks for the help and getting me up and running.
malum-in-se
I will go ahead and try and upgrade before I start plugging in my config stuff and see if I can get the newer version up and running and just change the web gui address.
malum-in-se
Weird... the upgrade somehow broke post processing, even though all the nzbtomedia stuff stayed exactly the same. I transfered over the sickbeard config stuff fine. Downloading and search are working great now...
My old nzbtomedia log when it worked had this:
[16:39:01] [INFO]::MAIN: #########################################################
[16:39:01] [INFO]::MAIN: ## ..::[nzbToMedia.pyc]::.. ##
[16:39:01] [INFO]::MAIN: Script triggered from SABnzbd
[16:39:01] [INFO]::MAIN: Auto-detected SECTION:SickBeard
[16:39:01] [INFO]::MAIN: Calling SickBeard:tv to post-process: (removed)
[16:39:01] [INFO]::MAIN: Attempting to auto-detect tv fork
[16:39:01] [INFO]::MAIN: SickBeard:tv fork auto-detection successful ...
now it looks the same except for the tv fork stuff
22:28:27] [INFO]::MAIN: #########################################################
[22:28:27] [INFO]::MAIN: ## ..::[nzbToMedia.pyc]::.. ##
[22:28:27] [INFO]::MAIN: #########################################################
[22:28:27] [INFO]::MAIN: Script triggered from SABnzbd
[22:28:27] [INFO]::MAIN: Auto-detected SECTION:SickBeard
[22:28:27] [INFO]::MAIN: Calling SickBeard:tv to post-process:(removed)
[22:28:27] [INFO]::MAIN: Attempting to auto-detect tv fork
[22:28:27] [INFO]::MAIN: SickBeard:tv fork auto-detection found custom params {}
[22:28:27] [INFO]::MAIN: SickBeard:tv fork set to custom
Then the logs are completely different.
Did you set the web_root and restart sickrage like in my blog post?
@Savell Martin
I finished the PBI (plugin) for Sonarr. It just needs to be pulled into the official repo.
sessus
Hey Joshua,
in your old installation guide you mention how to use a different sickbeard branch. I tried the same method with the current 9.3 plugin, but it doesn't seem to work. I get:
/usr/local/etc/rc.d/sickbeard: WARNING: failed to start sickbeard
Is there something I'm missing?
Hey Joshua,
I have no idea what steps you tried, can you post the commands you ran?
what branch are you trying to switch to?
sessus
rm -r /usr/pbi/sickbeard-amd64/share/sickbeard/Sick-Beard /usr/pbi/sickbeard-amd64/etc/sickbeard/* && git clone https://github.com/cytec/Sick-Beard.git /usr/pbi/sickbeard-amd64/share/sickbeard/Sick-Beard
Branch: https://github.com/cytec/Sick-Beard
The above is from your previous/old guide. It seems, though, that the folder structure has changed and the "/usr/pbi/sickbeard-amd64/etc/sickbeard" path is no longer valid.
yeah, its /var/db/sickbeard now. so just change that and it should work.
also make sure to 'chown media:media /usr/pbi/sickbeard-amd64/share/sickbeard/*' so your branch can auto-update itself.
AirborneTrooper
Got it all setup, but can't get sabnzb to post process. I turned off SickRage in the autoProcessMedia.cfg and entered used its settings for NzbDrone section. Changed the category section in sabnzb for tv to use NzbToNzbDrone.py script. I get this error after download completes:
           [16:01:27] [INFO]::MAIN: Loading config from [/usr/local/share/nzbToMedia/autoProcessMedia.cfg]
[16:01:27] [INFO]::MAIN: Checking database structure...
[16:01:27] [INFO]::MAIN: Checking if git needs an update
[16:01:28] [INFO]::MAIN: No update needed
[16:01:28] [INFO]::MAIN: nzbToMedia Version:bc2bab95ee4293775788bcb37eccf8333c7abb7a Branch:master (FreeBSD 9.1-RELEASE)
[16:01:28] [WARNING]::MAIN: Failed to locate 7zip. Transcosing of disk images and extraction of .7z files will not be possible!
[16:01:28] [INFO]::MAIN: #########################################################
[16:01:28] [INFO]::MAIN: ## ..::[nzbToMedia.pyc]::.. ##
[16:01:28] [INFO]::MAIN: Script triggered from SABnzbd
[16:01:28] [INFO]::MAIN: Auto-detected SECTION:NzbDrone
[16:01:28] [INFO]::MAIN: Calling NzbDrone:tv to post-process:Sons.of.Liberty.2015.S01E03.Independence.720p.HDTV.x264-DHD
[16:01:28] [INFO]::MAIN: Attempting to verify tv fork
[16:01:28] [INFO]::MAIN: NzbDrone:tv fork set to default
[16:01:29] [INFO]::TRANSCODER: Checking [Sons.of.Liberty.2015.E03.Independence.720p.HDTV.x264-DHD.mkv] for corruption, please stand by ...
[16:01:29] [INFO]::TRANSCODER: SUCCESS: [Sons.of.Liberty.2015.E03.Independence.720p.HDTV.x264-DHD.mkv] has no corruption.
[16:01:29] [INFO]::MAIN: FLATTEN: Flattening directory: /mnt/media/downloads/sabnzbd/complete/tv/Sons.of.Liberty.2015.S01E03.Independence.720p.HDTV.x264-DHD
[16:01:29] [POSTPROCESS]::NZBDRONE: SUCCESS: The download succeeded, sending a post-process request
[16:01:29] [ERROR]::NZBDRONE: Server returned status 405
[16:01:29] [ERROR]::MAIN: A problem was reported in the /usr/local/share/nzbToMedia/nzbToNzbDrone.py script.
NzbDrone: Failed to post-process - Server returned status 405!
jasn
I used Josh's blog, (and video), to successfully install SABNzbd, Couchpotato, Sickrage and Transmission, on the latest nightly of FreeNAS 9.3 Everything worked correctly, and I've even started downloading TV episodes with Sickrage. They're post processing and ending up in the correct /mnt/media/videos/tvshows/ directory.
The only issue I'm having is, (similar to the prior post), post processing via Couchpotato. After SABNzbd downloads the movie completely, the SABNzbd download screen lists the download with the following error message;
Exit(1) Exception AttributeError: "’NoneType’ object has no attribute ’path’" in (More)
Here's the Traceback section from the script log of the failed post processed download;
[15:45:42] [POSTPROCESS]::COUCHPOTATO: Starting renamer scan for movie.nzb
  File "/usr/local/share/nzbToMedia/nzbToCouchPotato.py", line 249, in <module>
  result = nzbToMedia.main(sys.argv, section)
  File "/usr/local/share/nzbToMedia/nzbToMedia.py", line 710, in main
  download_id='')
  File "/usr/local/share/nzbToMedia/nzbToMedia.py", line 595, in process
  inputCategory, failureLink)
  File "/usr/local/share/nzbToMedia/nzbtomedia/autoProcess/autoProcessMovie.py", line 242, in process
  result = r.json()
  File "/usr/local/share/nzbToMedia/libs/requests/models.py", line 759, in json
  return json.loads(self.text, **kwargs)
  File "/usr/local/lib/python2.7/json/__init__.py", line 338, in loads
  return _default_decoder.decode(s)
  File "/usr/local/lib/python2.7/json/decoder.py", line 366, in decode
  obj, end = self.raw_decode(s, idx=_w(s, 0).end())
  File "/usr/local/lib/python2.7/json/decoder.py", line 384, in raw_decode
  raise ValueError("No JSON object could be decoded")
ValueError: No JSON object could be decoded
Exception AttributeError: "'NoneType' object has no attribute 'path'" in <bound method PosixProcess.__del__ of <nzbtomedia.nzbToMediaUtil.PosixProcess instance at 0x807e7e9e0>> ignored
  download_id='')
  result = r.json()
did you restart CP after changing the web_root option? maybe it's not listening at http://jail_IP:5050/couchpotato yet? I don't mention to do this, but probably should.
jasn
Wow. Scary. A reboot is all it took. I don't know if I've ever followed such a complicated howto, and managed to get it working right on the first try, but it just happened. Great work Josh!
At this point I only have two other things. The first is if I want to add an additional plugin to this setup, like Headphones, would it mean following a similar methodology, uploading the plugin, configure it in the same jail, etc.?
The second thing is that I want to use this post to setup Transmission to use PIA VPN when it runs. If you have any advice I'd love to read it. I'm guessing if it's setup in the same jail and Transmission runs, it's going to setup the VPN for the jail at that point, and if SABNzbd is running, it would affect that service too. Is that correct?
Jason
@jasn
Thanks, I'm gonna add the steps to restart CP
yes, others have added headphones to this setup with the sane steps. I've just never used it myself.
yes I would think sabnzbd would be stuck using that tunnel also. you could experiment with running transmission in a different jail. it would take work, both transmission and sabnzbd need access to the same media dataset and nzbToMedia scripts. maybe just have 2 identical copies of nzbToMedia, or even store the scripts on the media dataset
