Resource icon
FN11.3 iocage jails - Plex, Tautulli, Sonarr, Radarr, Lidarr, Jackett, Transmission, Organizr
ZodiacUHD
I think I actually just ran into this. Updated to U2 and suddenly plex can't bind on start and fails:
Feb 21, 2018 14:20:17.594 [0x80a218000] ERROR - HttpServer: Error binding acceptor: Can't assign requested address
Feb 21, 2018 14:20:17.594 [0x80a218000] ERROR - Error: Unable to set up server: listen: Can't assign requested address (N5boost16exception_detail10clone_implINS0_19error_info_injectorINS_6system12system_errorEEEEE)
Interface in the jail is epair0 now. Debating how to proceed to get it back up and running, as even though it was requested over 5 years ago plex still can't bind to a specific interface.
I had the same issue. I ended up restoring 11.1u1. Sorry i cannot add much to the conversation, i'll wait for a solution as well.
ere109
"iocage had to change back to calling them epair0... during setup would it be best to define it in another way?
iocage exec <jail> 'sysrc ifconfig_epair0_name="epair0b"'
iocage restart <jail>@Celena
Given the above, would it make sense to drop vnet0 in place of epair0b in the setup? Do multiple name reassignments threaten to confuse the player?
Prasanth
Just upgraded to U2 and have issues trying access any of my iocage jail web interfaces. Did do the above changes with epair0b but didn't work . Also tried to downgrade to U1 and same issues cropped up there too. Is there a network setting I'm missing now?
Doing an ifconfig within the jail shows this
root@plex:~ # ifconfig
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
groups: lo
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:ff:60:14:fa:0a
hwaddr 02:e6:a0:00:09:0b
inet 192.168.2.103 netmask 0xffffff00 broadcast 192.168.2.255
nd6 options=1<PERFORMNUD>
status: active
groups: epair
root@plex:~ #
I tried to ping from server -> jail and I get a host is down message even though plex appears to be running and shows up in the freenas new GUI
Pistolwhip
groups: lo
options=8<VLAN_MTU>
status: active
groups: epair
root@plex:~ #
You might be missing the tuneables fix mentioned earlier in this thread which fix the initial setup of the veth bridge on system reboot. Basically the setup of the bridge device iocage uses needs to happen at boot right now, and you need to configure that to happen manually, else the bridge your jail is trying to use won't exist.
Prasanth
Thanks for the information. I added the tunables and restarted my freenas. Same issues. still unable to ping from server ->Jail and vice versa. I get "host is down"
kranzel
You can run this command inside the Jail and that solve the problem : sysrc ifconfig_epair0_name="epair0b"
Worked for me as well. Thank you.
Prasanth
Ok my mistake
in the tunables i just copied and pasted the igb0 that everyone else was when i should have been using em0 per my system.
thanks for the help!
cleansman
My iocage jails also stopped having outside network connectivity after the upgrade to U2.
Maybe somebody has an idea how I can fix this...
This is my setup with one jail activated:
I have configured the following rc.conf tunables:
cloned_interfaces=lagg0
ifconfig_lagg0=addm lagg0 up
iocage_enable=YES
Host network config
em0: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC>
ether 18:66:da:31:1d:33
hwaddr 18:66:da:31:1d:33
media: Ethernet autoselect
status: no carrier
em1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=9b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM>
ether 00:1f:29:56:a4:4d
hwaddr 00:1f:29:56:a4:4d
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
em2: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
hwaddr 00:1f:29:56:a4:4c
status: active
em3: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
hwaddr 00:1f:29:56:a4:4f
status: active
em4: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
hwaddr 00:1f:29:56:a4:4e
status: active
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x6
groups: lo
lagg0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
inet 10.10.10.13 netmask 0xffffff00 broadcast 10.10.10.255
status: active
groups: lagg
laggproto lacp lagghash l2,l3,l4
laggport: em1 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING>
laggport: em2 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING>
laggport: em3 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING>
laggport: em4 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING>
ether 02:dd:2e:0f:13:00
groups: bridge
member: vnet0:12 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 9 priority 128 path cost 2000
vnet0:12: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: plex
options=8<VLAN_MTU>
ether 02:ff:60:14:fa:09
hwaddr 02:d9:50:00:09:0a
status: active
groups: epair
Host route table:
root@freenas:~ # netstat -r
Routing tables
Internet:
Destination Gateway Flags Netif Expire
default 10.10.10.1 UGS lagg0
10.10.10.0/24 link#7 U lagg0
10.10.10.13 link#7 UHS lo0
localhost link#6 UH lo0
Internet6:
::/96 localhost UGRS lo0
::ffff:0.0.0.0/96 localhost UGRS lo0
fe80::/10 localhost UGRS lo0
fe80::%lo0/64 link#6 U lo0
fe80::1%lo0 link#6 UHS lo0
ff02::/16 localhost UGRS lo0
Outside ping is working on the host:
root@freenas:~ # ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8): 56 data bytes
64 bytes from 8.8.8.8: icmp_seq=0 ttl=61 time=14.334 ms
64 bytes from 8.8.8.8: icmp_seq=1 ttl=61 time=14.397 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=61 time=14.300 ms
^C
--- 8.8.8.8 ping statistics ---
3 packets transmitted, 3 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 14.300/14.344/14.397/0.040 ms
root@freenas:~ #
Jail network config
groups: lo
options=8<VLAN_MTU>
hwaddr 02:d9:a0:00:0a:0b
inet 10.10.10.50 netmask 0xffffff00 broadcast 10.10.10.255
status: active
groups: epair
Jail route table overview:
root@plex:~ # netstat -r
netstat: kvm not available: /dev/mem: No such file or directory
Routing tables
Internet:
default 10.10.10.1 UGS epair0b
10.10.10.0/24 link#2 U epair0b
10.10.10.50 link#2 UHS lo0
localhost link#1 UH lo0
Internet6:
fe80::%lo0/64 link#1 U lo0
fe80::1%lo0 link#1 UHS lo0
Outside ping is not working:
root@plex:~ # ping 8.8.8.8
ping: sendto: No route to host
^C
8 packets transmitted, 0 packets received, 100.0% packet loss
Mr Snow
This didn't actually work for me. I'm only having a problem with plex. Everything else works fine.
During initial setup of my jails, I specified to use a DHCP address
iocage create -n "plex" -r 11.1-RELEASE vnet=on dhcp=on bpf=yes allow_raw_sockets=1 boot=on
and when I try the epair0 rename thing, restarting the jail removes the line from rc.conf and replaces it with
ifconfig_epair0="DHCP"
I'm back on 11.1. Anyone have any thoughts? :)
Regards,
CJ
magev958
I’m a total newbie and tried to follow this tutorial but I can’t find the settings.json in Transmission to allow access to the webgui. I thing I tried every path on Google with no luck.
Please help
cleansman
Got it working.
ifconfig bridge0 addm lagg0 up
Solved it for me. [edit]Without any other tunables.[/edit]
ifconfig of the working setup
lagg0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=98<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM>
status: active
groups: lagg
groups: bridge
member: lagg0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 7 priority 128 path cost 5000
member: vnet0:1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
vnet0:1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
status: active
groups: epair
Prasanth
Also I noticed that sabnzbd was not updating and further research revealed it's set on a quarterly update cycle.
I did the following to make it use the latest instead
iocage exec sabnzbd 'mkdir -p /usr/local/etc/pkg/repos'
iocage exec sabnzbd 'ee /usr/local/etc/pkg/repos/FreeBSD.conf'
Copy and paste this into the file
FreeBSD: {
  url: "pkg+http://pkg.FreeBSD.org/${ABI}/latest"
fyi esc button shows menu and option is given to save while exiting out of ee(used to use nano but always ended up with errors when pasting text)
Then i just run to get the latest upgrade
iocage exec sabnzbd 'pkg update && pkg upgrade'
This is similar to the changes we made to plex in the resource to have it upgrade more frequently
more info at
https://forums.freebsd.org/threads/pkg-repository-changed-to-quarterly-in-10-2.52843/#post-296554
and
How to Update IOCAGE Jails
srtviperjr
Have a weird issue happening on my newly created transmission iocage jail. Followed the instructions but get the following issue when trying to start openvpn:
Cannot allocate TUN/TAP dev dynamically
Transmission works fine, turned off the firewall, blew away the iocage jail and recreated it - still no vpn
** EDIT ** Added the below:
 devfs rule -s 4 add path 'tun*' unhide
to pre-init on the freenas host, rebooted and all is good now.
afmiller
Which is better to use? Sabnzb or nbzget? Assuming you can use the same set up for openvpn like the instructions for transmission
ere109
Plex issue that I think I have a solution to - if it's repeating for others. Fresh install using the guide on Page 1 - editing fstab to put config off disk and mount media at /mnt/video. However, when I click "browse for media" Plex begins inside the "config" directory and won't allow me to browse back to the /mnt/video location. I can manually type /mnt/video to point to folders and build libraries, but I can't view/browse. Would it make sense to change the symlink landing point to something like:
iocage fstab -a plex /mnt/tank1/video /mnt/config/video nullfs ro 0 0
Are other people having this issue?
Celena
you can add manually the path without browsing like this :
It's in french but same window
afmiller
Ive tried to set up an openvpn gateway using your transmission w/ openvpn set up. But when I have ipfw started and I do a wget for the ip address, I get a valid ip address that is my real address. Also I am able to ping google.com. Below is what I've tried to mirror from the set up guide
# Allow internal traffic
add 03000 allow IP from 172.16.0.14/32 to 172.16.0.0/23 keep-state
add 03000 allow IP from 172.16.0.0/23 to 172.16.0.14/32 keep-state
# Allow access to Entrace IP for VPN
add 04000 allow IP from 172.16.0.14/32 to <IP of VPN Entrance Node> keep-state
# Allow any traffic over the VPN interface
add 05000 allow IP from any to any via tun*
# Deny any other traffic
add 65534 deny IP from any to any
I changed it to my current set up. This is in the /config/ipfw_rules. Which loads everytime I do service ipfw start
add 03000 allow IP from 192.168.1.2/24 to 192.168.0.0/24 keep-state
add 03000 allow IP from 192.168.0.0/24 to 192.168.1.2/24 keep-state
add 04000 allow IP from 192.168.1.2/24 to 108.0.0.0/8 keep-state
Here is what the loaded firewall rules look like with ipfw list
00100 allow ip from any to any via lo0
00200 deny ip from any to 127.0.0.0/8
00300 deny ip from 127.0.0.0/8 to any
00400 deny ip from any to ::1
00500 deny ip from ::1 to any
00600 allow ipv6-icmp from :: to ff02::/16
00700 allow ipv6-icmp from fe80::/10 to fe80::/10
00800 allow ipv6-icmp from fe80::/10 to ff02::/16
00900 allow ipv6-icmp from any to any ip6 icmp6types 1
01000 allow ipv6-icmp from any to any ip6 icmp6types 2,135,136
03000 allow ip from 192.168.1.0/24 to 192.168.0.0/24 keep-state :default
03000 allow ip from 192.168.0.0/24 to 192.168.1.0/24 keep-state :default
04000 allow ip from 192.168.1.0/24 to 108.0.0.0/8 keep-state :default
05000 allow ip from any to any via tun*
65534 deny ip from any to any
65535 allow ip from any to any
Michael De Cou
Tried following your plexpass tutorial, but running into issues with it.
I follow these steps but get the error below. I am unable to outside ips inside the jail and unable to ping to the .150 from other PCs
echo '{"pkgs":["plexmediaserver-plexpass","ca_root_nss"]}' > /tmp/pkg.json
iocage create -n "plex" -p /tmp/pkg.json -r 11.1-RELEASE ip4_addr="vnet0|<192.168.1.150/24" defaultrouter="192.168.1.1" vnet="on" allow_raw_sockets="1" boot="on"
Error
root@freenas:~ # iocage create -n "plex" -p /tmp/pkg.json -r 11.1-RELEASE ip4_addr="vnet0|192.168.1.150/24" defaultrouter="192.168.1.1" vnet="on" allow_raw_sockets="1" boot="on"
plex successfully created!
Testing SRV response to FreeBSD
Error: error sending query: Error creating socket
Command run: drill _http._tcp.pkg.freebsd.org SRV
root@freenas:~ #
Thanks for the Help
Did you get this resolved? I am having the same problem. I have tried the tunables, with no luck.
