Export/Disconnect pool gave ZFS Encryption? Data lost?
Settler11
So I was testing around with my Testpool. The pool wasn't encrypted. But after trying out the Export/disconnect pool and restoring the pool to the same disk, it got locked and it's asking for a Key file or Dataset Key (which I don't have)
Short question: is the data on the Testpool now all loss since I didn't do encryption on my disks...?
Other question: is the data on there salvageable after getting locked?
Settler11
Via the discord server I've been told its a lost cause.. But I'm wondering if anyone else on the forum got a workaround perhaps.
You say you didn't use encryption, but clearly the root dataset is encrypted.
Settler11
I'm very sure it wasn't before the Export/disconnecting pool. Otherwise I'd have a place I know for the prompt Key which should generate when you encrypt. And I basically copied what I did with the first dataset which is Unencrypted.
What does this reveal:
zfs list -t filesystem -r -o name,encryption,keyformat,encryptionroot Testpool
This means you enabled the encryption option when you created the pool.
