- May 28, 2011
@DarkCorner This is the second time you have entered a command incorrectly in this thread. You need to slow down and pay closer attention to the commands you enter or one day you will enter a command that will cause you a lot of grief."iostat" - not "iostack"
Wow, I'm very surprised actually, I would have expected some SWAP usage. If you use the GUI and go to Reporting/Memory, find the SWAP chart, and then use the (-) button to cover a greater span of time, in fact all of time recorded (at least the past month), then it will give you the min/max values of SWAP utilized. If it turns out to remain at zero, that is very good, but with the limited RAM you have, I really am surprised. And this may not have anything to do with the slow drive condition, it's just something to look at.Swap = 0Kb
And thanks for posting the output of the commands I requested, I see nothing wrong there.
