Ctl_datamove HP proliant dl180 G9 FreeNAS 11.0 U2 guidance requested
abrowne001
I am trying to troubleshoot an error message of ctl_datamove: tag 0xfd108db on (1:3:0) aborted the tag and the (x:x:x) numbers change. I am unable to locate any current negative side effects at the moment I went through the logs and the only thing I am able to locate that is bad with my limited experience is collectd[5740]: aggregation plugin: Unable to read the current rate of "xxx-xxx-xxxx.xxxxxxxx.com/cpu-4/cpu-user" collectd[5740]: utils_vl_lookup: The user object callback failed with status 2. My research tells me that it is a bug and is slated to be fixed in 11.1. I have attached a copy of my messages log and the debug log. If there is anything else that is required to guide me in the right direction please let me know. Thanks in advance
FreeNAS 11.0 U2
  • messages - debug.zip
D
dlavigne
Guest
Hard to tell without a full debug. How full is the pool? How many jails/plugins/VMs are installed?
abrowne001
As it turns out I was overworking my storage solution with 7200 rpm drives. Working on a solution for my user configuration mistake.
