TrueCommand Docker Container
aervin
@jon.z -- Unfortunately, we're only able to support Linux kernel 4+ at this time. We've updated the container's requirements on DockerHub to avoid future confusion. Apologies for the inconvenience.
jon.z
@aervin Thank you for looking into this further :)
/var/log/ix_middleware.log
root@f80a465cac9a:~# cat /var/log/ix_middleware.log
[STARTING] "Thu Apr 23 00:10:54 2020"
Opening Database...
Creating the TrueCommand Database: ixdb
Database error: "could not connect to server: Connection refused\n\tIs the server running on host \"localhost\" (127.0.0.1) and accepting\n\tTCP/IP connections on port 5432?\ncould not connect to server: Cannot assign requested address\n\tIs the server running on host \"localhost\" (::1) and accepting\n\tTCP/IP connections on port 5432?\nQPSQL: Unable to connect"
Could not open database!!
Server could not be started: 2020-04-23T00:10:54
 - Tried ports: 5182 5183
QThread: Destroyed while thread is still running
[STARTING] "Thu Apr 23 00:10:55 2020"
Opening Database...
Database error: "FATAL:  the database system is starting up\nFATAL:  the database system is starting up\nQPSQL: Unable to connect"
Server could not be started: 2020-04-23T00:10:55
[STARTING] "Thu Apr 23 00:10:57 2020"
Opening Database...
Database Connected
DB ERROR: "ERROR:  null value in column \"tvinstanceuid\" violates not-null constraint\nDETAIL:  Failing row contains (null, null, 5443a61b).\n(23502) QPSQL: Unable to create query"
 - query: "INSERT INTO tv.license (anonid) VALUES ('5443a61b');"
Using SSL Library:
 - Version: "OpenSSL 1.1.1d  10 Sep 2019"
   WS server started on port number 5182
 HTTP server started on port number 5183
Nothing of note in the nginx, pgsql or supervisord log files.
I tested a SSL connection to a FreeNAS system, from inside the container. As you can see, this works. However systems are reported as offline in the TrueComamnd GUI (see attached screenshots).
root@f80a465cac9a:~# echo "GET / HTTP/1.1" | openssl s_client -connect freenas_host:443
CONNECTED(00000003)
...removed certificate details...
No client certificate CA names sent
Peer signing digest: SHA512
Peer signature type: RSA
Server Temp Key: ECDH, P-256, 256 bits
SSL handshake has read 2758 bytes and written 451 bytes
Verification error: self signed certificate in certificate chain
New, TLSv1.2, Cipher is ECDHE-RSA-AES256-GCM-SHA384
Server public key is 2048 bit
Secure Renegotiation IS supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
    Protocol  : TLSv1.2
    Cipher    : ECDHE-RSA-AES256-GCM-SHA384
    Session-ID: 61344AC0CC41361E9D4CA6806C0D8EA12689ABF9FC86ADE7F4DC97CDF19C08DE
    Session-ID-ctx:
    Master-Key: AB2CEBC2C2580C4B229C49404747DFE93EBF8F96B52B3E16A4A2070A2AFC60D45C89083D2DED6FC13A8541EC8EA787B2
    PSK identity: None
    PSK identity hint: None
    SRP username: None
    TLS session ticket lifetime hint: 7200 (seconds)
    TLS session ticket:
    0000 - 9b ca b8 cd 53 c6 f9 90-b6 d5 a4 33 44 a8 2f d5   ....S......3D./.
    0010 - ed e4 59 cd b3 2a 80 f5-e9 32 3a 99 aa df a1 35   ..Y..*...2:....5
    0020 - b6 1a 58 07 94 f1 14 41-a8 57 ca f8 86 31 ff c0   ..X....A.W...1..
    0030 - 0a c0 ac 14 c9 96 91 94-cb 30 2e 50 de 12 1a 55   .........0.P...U
    0040 - 9a 0f a9 01 d3 d6 4a fd-21 5f d2 3c bd 85 eb 64   ......J.!_.<...d
    0050 - a6 2d 97 50 99 34 f0 7f-be 63 40 34 ec 83 47 54   .-.P.4...c@4..GT
    0060 - 9d a3 51 29 2c 05 db 23-b9 a4 73 c8 b8 21 6e d7   ..Q),..#..s..!n.
    0070 - 2b 7b b0 ac a3 21 45 db-da da 61 37 44 71 40 33   +{...!E...a7Dq@3
    0080 - 88 44 7c 7f fd 92 65 d9-57 b4 25 17 9e 3a 1c 7f   .D|...e.W.%..:..
    0090 - 4a 81 84 9c e4 95 f9 41-5f 45 02 30 40 c1 af f1   J......A_E.0@...
    00a0 - 1d 85 1a 89 57 d5 fc 67-46 ed 22 ea c4 7b 09 80   ....W..gF."..{..
    00b0 - f6 f8 86 25 f9 0d 79 7c-3d 29 d3 32 3f ae 5c 78   ...%..y|=).2?.\x
    00c0 - bc ba c8 fd 03 ad 24 bb-68 01 b5 2b b3 6c 9a be   ......$.h..+.l..
    Start Time: 1587603743
    Timeout   : 7200 (sec)
    Verify return code: 19 (self signed certificate in certificate chain)
    Extended master secret: no
DONE
jon.z
Further, I also ran a basic tcpdump on VM's Docker Swarm gateway interface, while testing the SSL connection per above (i.e. within a shell on the container). As you can see, this verifies there is no network connectivity issue from the container to the FreeNAS system (and from the system to the container). I will note however, tcpdump does not capture ANY traffic from the TrueCommand container when it's started, restarted, or when removing all systems and adding them again. I would expect to see network traffic while preforming those actions. As such, this suggests to me an application level issue.
# tcpdump -i docker_gwbridge -n host freenas_host
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on docker_gwbridge, link-type EN10MB (Ethernet), capture size 262144 bytes
01:30:42.334539 IP 172.18.0.4.35606 > freenas_host.https: Flags , seq 2774496244, win 29200, options [mss 1460,sackOK,TS val 170260056 ecr 0,nop,wscale 7], length 0
01:30:42.428686 IP freenas_host.https > 172.18.0.4.35606: Flags [S.], seq 2378697687, ack 2774496245, win 65535, options [mss 1288,nop,wscale 6,sackOK,TS val 3520597567 ecr 170260056], length 0
01:30:42.428731 IP 172.18.0.4.35606 > freenas_host.https: Flags [.], ack 1, win 229, options [nop,nop,TS val 170260150 ecr 3520597567], length 0
01:30:42.429063 IP 172.18.0.4.35606 > freenas_host.https: Flags [P.], seq 1:326, ack 1, win 229, options [nop,nop,TS val 170260150 ecr 3520597567], length 325
01:30:42.524187 IP freenas_host.https > 172.18.0.4.35606: Flags [.], seq 1:1277, ack 326, win 1026, options [nop,nop,TS val 3520597662 ecr 170260150], length 1276
01:30:42.524223 IP freenas_host.https > 172.18.0.4.35606: Flags [P.], seq 1277:2485, ack 326, win 1026, options [nop,nop,TS val 3520597662 ecr 170260150], length 1208
01:30:42.524261 IP 172.18.0.4.35606 > freenas_host.https: Flags [.], ack 1277, win 251, options [nop,nop,TS val 170260246 ecr 3520597662], length 0
01:30:42.524272 IP 172.18.0.4.35606 > freenas_host.https: Flags [.], ack 2485, win 274, options [nop,nop,TS val 170260246 ecr 3520597662], length 0
01:30:42.525321 IP 172.18.0.4.35606 > freenas_host.https: Flags [P.], seq 326:452, ack 2485, win 274, options [nop,nop,TS val 170260247 ecr 3520597662], length 126
01:30:42.620140 IP freenas_host.https > 172.18.0.4.35606: Flags [P.], seq 2485:2759, ack 452, win 1026, options [nop,nop,TS val 3520597758 ecr 170260247], length 274
01:30:42.620683 IP 172.18.0.4.35606 > freenas_host.https: Flags [P.], seq 452:496, ack 2759, win 294, options [nop,nop,TS val 170260342 ecr 3520597758], length 44
01:30:42.620721 IP 172.18.0.4.35606 > freenas_host.https: Flags [FP.], seq 496:527, ack 2759, win 294, options [nop,nop,TS val 170260342 ecr 3520597758], length 31
01:30:42.714793 IP freenas_host.https > 172.18.0.4.35606: Flags [.], ack 528, win 1025, options [nop,nop,TS val 3520597853 ecr 170260342], length 0
01:30:42.714833 IP freenas_host.https > 172.18.0.4.35606: Flags [F.], seq 2759, ack 528, win 1026, options [nop,nop,TS val 3520597853 ecr 170260342], length 0
01:30:42.714852 IP 172.18.0.4.35606 > freenas_host.https: Flags [.], ack 2760, win 294, options [nop,nop,TS val 170260436 ecr 3520597853], length 0
Please let me know if you require any further data.
Tony-1971
From docker container I can't reach FreeNAS server:
[tony@docker-server ~]$ docker container exec -it loving_bell /bin/bash
root@9892b3253015:~# nc 192.168.50.3 80
Ncat: No route to host.
root@9892b3253015:~# nc 192.168.50.3 443
root@9892b3253015:~# nc 192.168.50.3 22
But from another container on the same network I can reach the server:
[tony@docker-server ~]$ docker container attach alpine1
/ # ping 192.168.50.3
PING 192.168.50.3 (192.168.50.3): 56 data bytes
64 bytes from 192.168.50.3: seq=0 ttl=63 time=1.041 ms
64 bytes from 192.168.50.3: seq=1 ttl=63 time=0.678 ms
64 bytes from 192.168.50.3: seq=2 ttl=63 time=0.481 ms
64 bytes from 192.168.50.3: seq=3 ttl=63 time=0.563 ms
64 bytes from 192.168.50.3: seq=4 ttl=63 time=0.644 ms
^C
--- 192.168.50.3 ping statistics ---
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 0.481/0.681/1.041 ms
/ # nc 192.168.50.3 80
/ # nc 192.168.50.3 443
/ # read escape sequence
And this is the network configuration:
[tony@docker-server ~]$ docker network inspect my-net
        "Name": "my-net",
        "Id": "666f9979e66eb747b26d8597e28d7f1b17dd9690d748146746a97c6a23dfdad6",
        "Created": "2020-04-24T11:25:16.448601611+02:00",
        "Scope": "local",
        "Driver": "bridge",
        "EnableIPv6": false,
        "IPAM": {
            "Driver": "default",
            "Options": {},
            "Config": [
                    "Subnet": "172.18.0.0/16",
                    "Gateway": "172.18.0.1"
        "Internal": false,
        "Attachable": false,
        "Ingress": false,
        "ConfigFrom": {
            "Network": ""
        "ConfigOnly": false,
        "Containers": {
            "9892b3253015488c3b00ae460ea1098d9a8ae74b8f16f0f10a20d842d03c5d21": {
                "Name": "loving_bell",
                "EndpointID": "15b02a80daf6aa88ff26293ef780eb5b6e22eb245864158af584d0363260c067",
                "MacAddress": "02:42:ac:12:00:02",
                "IPv4Address": "172.18.0.2/16",
                "IPv6Address": ""
            "9dfa7116923c33f470ac2fc830eb6239fd2a7de6c8b38a1d174515fa4d2d8947": {
                "Name": "alpine1",
                "EndpointID": "ec17b666fbf1db91a8f1f331abe22e4172f1534c49fe625ad525168f2a288dd0",
                "MacAddress": "02:42:ac:12:00:03",
                "IPv4Address": "172.18.0.3/16",
                "IPv6Address": ""
        "Options": {},
        "Labels": {}
Also the log file is container is the same of @jon.z above.
P.S.: Resolved installing Docker Container in Fedora Server 31
Best Regards,
Antonio
rookie_eyes
TrueCommand 1.2 is now available as a Docker image on the Docker Hub.
A TrueCommand container should be deployable on any Container management platform that can support Docker Hub and its images.
Please respond to this post if you:
  • Have any deployment issues with the Docker image
  • Successfully validate on a new container environment
  • Have any container-related advice for the community
  • Have any container-related suggestions for the developers
Hey There,
Do we happen to know if the True Command docker image has been tested on a Raspberry Pi 4???? I'm wanting to deploy true command via this solution but I think my current raspberry pi 3B isn't man enough. I wanted to see if someone's tested this before I go and spend out on a new one.
Thanks in advance.
Heracles
Hey There,
Thanks in advance.
Hey @rookie_eyes,
A Raspberry PI is not running an Intel processor. It is running an ARM processor. As such, the code must be recompiled for that. Until you see a docker container compiled for ARM, there is nothing to test....
rookie_eyes
Hey @rookie_eyes,
is there an area to request this? Happy to be a guinea pig! :) I happen to love the idea of running this sort of container on a Pi. With companies like Apple going 100% ARM next year it seems like a good time to get this into at least development phase :-S
freenasmww
I'm unable to get the Docker container started in my enviornment.
Starting TrueCommand: Mon Dec 21 10:45:03 EST 2020
Starting Services [1/3]
Starting PostgreSQL 11 database server: main.
Starting Services [2/3]
nginx: [emerg] socket() [::]:80 failed (97: Address family not supported by protocol)
[ERROR] Could not start Nginx!
 - Finished: Mon Dec 21 10:45:05 EST 2020
Google tells me this is because NGINX is attempting to bind with IPV6. I do not have IPV6 enabled on the underlying host.
Jaron
iX IT Mgr
Administrator
Did you manually disable IPv6 on your Host? There was a period of time that nginx failed to launch if the host did not support IPv6. I believe this was fixed, we will look into that. in the meantime, you can enable IPv6 and just not use it. or the nginx configuration in the docker container will need to be modified for remove the listen [::]:80 directive.
freenasmww
I do not specifically remember disabling IPV6. However I would prefer it remain disabled.
How should the nginx configuration be modified?
Jaron
iX IT Mgr
Administrator
I loaded the up a VM with Debian 10.7, the latest version of docker and our Truecommand Docker image with ipv6 disabled on the host system and I was unable to recreate this issue. So I do not believe the configuration needs to be edited. Can you give me more specific of your specific setup? What OS and version are you running on the host? is this it he latest truecommand docker container you are trying to run? Is the Host system a fresh install?
freenasmww
I believe I am pulling the latest version.
cat truecommand.yml
version: "3.8"
services:
  truecommand:
    environment:
      - PUID=${PUID}
      - PGID=${PGID}
      - TZ=${TZ}
    volumes:
      - ${USERDIR}/docker/truecommand/data:/data
    ports:
      - 9490:80
      - 9491:443
    restart: unless-stopped
    container_name: truecommand
    image: ixsystems/truecommand
It is not a fresh build.
cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=18.04
DISTRIB_CODENAME=bionic
DISTRIB_DESCRIPTION="Ubuntu 18.04.5 LTS"
My network interfaces are defined by Netplan. I have not specifically disabled IPV6, nor have I enabled it.
cat /etc/netplan/01-netcfg.yaml
# This file describes the network interfaces available on your system
# For more information, see netplan(5).
network:
  version: 2
  renderer: networkd
  ethernets:
    eth0:
      match:
        macaddress: xxxxxxxxxx
      dhcp4: yes
    eth1:
      match:
      addresses:
        - 10.0.10.2/24
      mtu: 9000
The following parameters have been modified.
cat /etc/sysctl.d/99-network-tuning.conf
net.core.rmem_max = 16777216
net.core.wmem_max = 16777216
net.core.rmem_default = 16777216
net.core.wmem_default = 16777216
net.core.optmem_max = 40960
net.ipv4.tcp_rmem = 4096 1048576 2097152
net.ipv4.tcp_wmem = 4096 65536 16777216
net.core.netdev_max_backlog = 100000
net.core.netdev_budget = 50000
net.core.netdev_budget_usecs = 5000
net.ipv4.tcp_max_syn_backlog = 30000
net.ipv4.tcp_max_tw_buckets = 2000000
net.ipv4.tcp_tw_reuse = 1
net.ipv4.tcp_fin_timeout = 10
net.ipv4.tcp_slow_start_after_idle = 0
Docker and Docker Compose Versions
docker --version
Docker version 19.03.13, build 4484c46d9d
docker-compose --version
docker-compose version 1.27.4, build 40524192
Docker DIR Permissions
sudo usermod -aG docker ${USER}
mkdir ~/docker
sudo setfacl —no-mask -Rdm g:docker:rwx ~/docker
sudo chmod -R 775 ~/docker
getfacl docker
# file: docker
# owner: mark
# group: mark
user::rwx
group::rwx
other::r-x
default:user::rwx
default:group::rwx
default:group:docker:rwx
default:mask::rwx
default:other::r-x
Something looks off w/ the resultant permissions after the first run of the container.
~/docker/truecommand/data$ ls -al
total 12
drwxr-xr-x+  3 root  root  4096 Dec 21 10:44 .
drwxr-xr-x+  3 root  root  4096 Dec 21 10:44 ..
drwx------  19 uuidd uuidd 4096 Dec 21 10:45 ixdb
Compared to another container as an example.
~/docker/homebridge$ ls -al
total 228
drwxr-xr-x+  7 mark docker   4096 Nov 14 16:46 .
drwxrwxr-x+ 12 mark mark     4096 Dec 21 10:44 ..
-rw-r--r--+  1 mark docker     81 Aug 13 12:48 .docker.env
-rw-rw-r--+  1 mark docker    663 Aug 13 12:51 .uix-dashboard.json
-rw-rw-r--+  1 mark docker     81 Aug 13 12:48 .uix-secrets
drwxrwxr-x+  2 mark docker   4096 Sep  4 11:46 accessories
-rw-rw-r--+  1 mark docker    359 Aug 13 12:48 auth.json
drwxrwxr-x+  4 mark docker   4096 Nov 15 01:15 backups
-rw-rw-r--+  1 mark docker    407 Sep  4 07:35 config.json
-rw-rw-r--+  1 mark docker 152685 Dec 22 01:15 homebridge.log
drwxrwxr-x+  2 mark docker   4096 Aug 13 12:48 logs
drwxrwxr-x+  5 mark docker   4096 Sep  4 07:35 node_modules
-rw-rw-r--+  1 mark docker  12653 Nov 14 16:46 package-lock.json
-rw-r--r--+  1 mark docker    196 Sep  4 07:35 package.json
drwxrwxr-x+  2 mark docker   4096 Aug 13 12:48 persist
-rwxr-xr-x+  1 mark docker    573 Aug 13 12:48 startup.sh
Tasmana
Error after update kernel. Can u healp me?
Database Connected
Using SSL Library:
Segmentation fault (core dumped)
 - Finished: Thu Feb 25 14:59:12 EET 2021
Starting TrueCommand: Thu Feb 25 14:59:25 EET 2021
ln: failed to create symbolic link '/etc/ssl/certs/./tc-test-test.pem': File exists
Starting Services [3/3]
[STARTING] "Thu Feb 25 14:59:28 2021"
Opening Database...
Database Connected
Using SSL Library:
 - Finished: Thu Feb 25 14:59:29 EET 2021
Heracles
Spammer ; reported to the Mods already
I have just moved my docker instance to a new VM and spun up Truecommand. I am getting zombie processes on that VM coming from truecommand-mw.
I don't recall seeing a zombie process for caddy and truecommand on my old Docker instance so I was wondering what I may have done wrong.
Here is my compose for a custom template in Portainer. It's the same code I have used for the past 2 years, I just changed it from V1.2 to latest on the image tag about 8 months or so ago when I noticed I wasn't getting the new version update.
