9.3 How to build and install LMS 7.9 from scratch
Roger Wilco
@Fraoch
You do not need to set any passwords in any scripts.
Do the created log files have 'lms' as owner and group?
I have
ls -al /var/log/lms/
total 20
drwxr-xr-x  2 lms   lms       5 Mar 21 22:57 .
drwxr-xr-x  3 root  wheel    43 Apr  2 23:00 ..
-rw-r--r--  1 lms   lms       0 Mar  3 22:17 perfmon.log
-rw-r--r--  1 lms   lms       0 Mar 21 23:20 scanner.log
-rw-r--r--  1 lms   lms    3054 Mar 28 00:44 server.log
What permissions does the lms script have?
I have
ls -al /usr/local/etc/rc.d/lms
-r-xr-xr-x  1 root  wheel  2745 Mar 31 01:24 /usr/local/etc/rc.d/lms
Just a shot in the dark, in the /usr/local/etc/rc.d/lms script the following lines need to look exactly this way:
# PROVIDE: lms
# REQUIRE: LOGIN
# KEYWORD: shutdown
Do not add or remove any whitespaces or anything or it won't work. See
The format of the lines is rigid. Each line must begin with a single `#', followed by
a single space, followed by ``PROVIDE:'', ``REQUIRE:'', ``BEFORE:'', or
``KEYWORD:''. No deviation is permitted.
in rcorder(8).
Did you create the file under Windows? Windows uses different line endings than Unix-like OSes (\r\n vs. \n). -Editor you'd see those ^M characters at the end of a line:
Vim with ^M
Can you post the output of:
rcorder /etc/rc.d/* /usr/local/etc/rc.d/*
Do you get this output:
service lms rcvar
# lms
lms_enable="YES"
#   (default: "")
service lms rcvar
If these things are also ok, then I am clueless, and you'll need to start reading how the rc.d framework works. A good starting point is
Practical rc.d scripting in BSD
HTH,
rw
Fraoch
I have
total 20
Same here:
ls -al /var/log/lms
total 26
drwxr-xr-x  2 lms  lms  5 Apr  2 09:06 .
drwxr-xr-x  3 root  wheel  29 Apr  5 00:00 ..
-rw-r--r--  1 lms  lms  0 Apr  1 10:25 perfmon.log
-rw-r--r--  1 lms  lms  6563 Apr  1 10:28 scanner.log
-rw-r--r--  1 lms  lms  582 Apr  2 09:15 server.log
I have
Looks fine:
-r-xr-xr-x  1 root  wheel  3311 Apr  1 09:27 /usr/local/etc/rc.d/lms
# PROVIDE: lms
# REQUIRE: LOGIN
# KEYWORD: shutdown
Also no problems that I can see:
  # PROVIDE: lms
  # REQUIRE: LOGIN
  # KEYWORD: shutdown
Vim with ^M
No, I created this file in an SSH session using nano. I copied and pasted it from this thread. Sometimes when I do that, line breaks get inserted where there shouldn't be and several lines were split up inappropriately in this file - I edited it and went through the file several times to make sure there are no improper line breaks.
service lms rcvar
# lms
lms_enable="YES"
#   (default: "")
service lms rcvar
AHA! No, I do not get this at all. I get a long listing:
http://pastebin.com/Akz7awgW
I notice that /usr/local/etc/rc.d/lms is listed there, but the output isn't close to yours.
Thanks for your help!
Roger Wilco
Looks fine:
How comes your script is longer than mine?
No. Your posted link is the output of
Here's mine:
http://pastebin.com/w44RWMRG
Your lms script is invoked much earlier that mine - it should be invoked after
/etc/rc.d/LOGIN
which is what the following line inside the lms-script says:
# REQUIRE: LOGIN
To be honest, I have no idea why. You could diff your and mine rcorder output and go through the not matching dependencies, but I still think there's something wrong with the lms-script.
Try to write a dummy rc.d-script like in the link I posted the last time to see whether it is invoked after /etc/rc.d/LOGIN
Sorry,
rw
Fraoch
Very good question...it's nothing I can see. Whitespace? I'm finding some whitespace before line breaks and as I eliminate it, the script gets smaller by a few bytes.
Ah well. I think there's something wrong with my script although I can't see any differences between it and the one you posted (I copied-pasted in nano). I appreciate the help. I'll start just LMS manually.
Thank you Roger.
Roger Wilco
@Fraoch
You can get my lms file here:
http://pastebin.com/jtuvqvEJ
It is base64 encoded, just to make sure there are no whitespace problems or the like. Instructions how to decode it are also there...
In case it works, let me know :)
-rw
Fraoch
And that was it! It works! :D
I followed your instructions to decode it back into text and checked the MD5. It matched. I then copied the tmp file over to /usr/local/etc/rc.d/lms.
I checked the file with nano. I immediately noticed there were no whitespaces in front of each line - I've never used pastebin before, copying and pasting seems to add 4-5 spaces before each line.
Now LMS starts with every restart!
THANK YOU!:)
Roger Wilco
@Fraoch
This is funny.
After I had posted the script in this thread I copied it into a file and everything was fine, so I didn't bother to put it on pastebin.
Right now I've checked the script from this thread against the one which now works for you, and the diff doesn't show any problematic things (only tabs have been replaced with spaces, and each empty line has one space added (I think, maybe I've removed them in my local version - don't know anymore)).
Basically copying the script from this thread into a file should be fine... (at least with vim - I've never used nano...)
Anyway, who cares - it works now :)
-rw
Bidule0hm
Server Electronics Sorcerer
If it's useful to someone: I never had a problem copy-pasting from a text editor or a pastebin to nano in a SSH session on PuTTY but I know there is many problems with the web GUI terminal and with copy-pasting directly from the forum.
metz2
The build failed for me.
What was different from the first post for me was that I had to install newer versions of these because they were not available anymore:
  1. pkg install nasm-2.11.06,1
  2. pkg install wget-1.16
And perl is now version 5.20.
Is it possible that this made the build fail?
Unfortunately, I got frustrated and deleted the jail including the log file...
Jollybully
The build failed for me too after following the guide. Everything fell down at:
libmediascan-0.1/bindings/perl. make failed, aborting
glennpm
I was able to get LMS working last night with a modified version of the instructions in this thread. Unlike the similar thread with the binary pre-packaged, the LMS built with these instructions includes album art.
I started with post #1 of this thread. The /usr/bin/perl reference is not updated after the initial upgrade -- it points to the now-dead perl5.18.4:
pkg update
pkg upgrade
I chose to fix this by re-creating the /usr/bin/perl link (I am not a FreeBSD expert, so there may be a better way to do this):
rm /usr/bin/perl
ln -s /usr/local/bin/perl5.20.2 /usr/bin/perl
I then found that the install references to nasm and wget no longer existed, so I used the following instead:
pkg install nasm
pkg install wget
Next, you have to substitute the correct logitechmediaserver reference. This comes from whichever version you choose to use from downloads.slimdevices.com.
wget http://downloads.slimdevices.com/nightly/7.9/sc/<YOUR SUBDIRECTORY>/logitechmediaserver-7.9.0-<YOUR VERSION STAMP>.tgz
tar xf logitechmediaserver-7.9.0-<YOUR VERSION STAMP>.tgz
You have to do this substitution throughout the instructions.
Next, you have to substitute "5.20" for "5.18" wherever it occurs in the instructions. So
cd /tmp/somedir/logitechmediaserver-7.9.0-<YOUR VERSION STAMP>/CPAN/arch/5.18
becomes
cd /tmp/somedir/logitechmediaserver-7.9.0-<YOUR VERSION STAMP>/CPAN/arch/5.20
You also have to do the reverse and substitute 5.18 in the one instruction where it says 5.20. (instruction 7 under 'Remove the unused perl branches:')
rm -rf 5.18
After switching from the build_jail to the install jail remember to update the perl reference after the upgrade:
rm /usr/bin/perl
Finally, I switched to the instructions in post #17 where it says to do so in post #1.
Everything seems to be working well now. Thanks to everyone who did all the heavy lifting!
Teots
I still have quite a lot of trouble getting this to run under the latest jail version (with Perl 5.20) and the latest commit on the public/7.9 branch (1e48070f96eea5f0434b3e0810b986dfaee50f6a).
perl -v
This is perl 5, version 20, subversion 2 (v5.20.2) built for amd64-freebsd-thread-multi
When I run the buildme.sh script it fails with:
/usr/bin/ld: /slimdevices/slimserver-vendor/CPAN/build/include/../lib/libavcodec.a(deinterlace.o): relocation R_X86_64_PC32 against `ff_pw_4' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: final link failed: Bad value
*** [blib/arch/auto/Media/Scan/Scan.so] Error code 1
Stop in /slimdevices/slimserver-vendor/CPAN/libmediascan-0.1/bindings/perl.
Does anybody know how to fix that?
Get Amped
The user 'fydo' over at forums.slimdevices.com posted something that fixed a similar problem for him:
I did some digging in the buildme.sh script and found this line:
ARCH=`/usr/bin/perl -MConfig -le 'print $Config{archname}' | sed 's/gnu-//' | sed 's/^i[3456]86-/i386-/' | sed 's/armv5tejl/arm/' `
However, when I run that command on the commandline, I get "amd64-freebsd-thread-multi" as a result. Presumably the "-thread-multi" is there because my perl is compiled with threading enabled.
The script checks for "amd64-freebsd" when compiling ffmpeg and since that's not exactly what my arch is, the 64-bit compile flag doesn't get set. I changed the script to always add the 64-bit compile flag and that solved it for me.
I am getting the same error as Teots using the latest 7.9 nightly and incorporating the changes to the process posted by glennpm. Unfortunately, I have no idea how to "always add the 64-bit compile flag" or if that will actually solve this error. Any assistance is greatly appreciated.
Get Amped
I have successfully built and am running the latest 7.9 nightly (1438870722) in a FreeBSD jail on FreeNAS FreeNAS-9.3-STABLE-201506292332 on an HP Microserver Gen8 with 10GB RAM, a 16GB flash drive, a 120GB Samsung SSD and 4 x 4TB WD Red HDs.
My goal was to have 10TB+ of lz4 storage for media and run LMS on the SSD. FreeNAS boots from the flash drive installed in the internal USB port, the SSD uses the ODD bay and SATA connector and the WD Reds are in the 4 drive trays.
I struggled with getting LMS to build working from the information in this thread and tried at least a half dozen times before I found the path. The following commands are exactly what I used as I went through the process successfully. You will have to adapt them to your directory/storage structures as appropriate. The key to getting it working was making sure the symbolic links to perl/perl5 were done/redone in both jails.
Create two jails: one to build LMS and one to run it. Use Advanced mode, enter the IPv4 default gateway and check VIMAGE.
In build_LMS jail:
pkg update
pkg upgrade
pkg install bash
pkg install gmake
pkg install rsync
pkg install nasm
pkg install wget
pkg install libgd
mkdir /tmp/LMS
cd /tmp/LMS
wget linktothenightlybuildthatIcan'tputherebecauseIdon'thaveenoughposts
tar xf logitechmediaserver-7.9.0-1438870722.tgz
git clone linktothesourcerepositorythatIcan'tputherebecauseIdon'thaveenoughposts
ln -s -f /usr/local/bin/perl5.20.2 /usr/bin/perl
ln -s -f /usr/local/bin/perl5.20.2 /usr/bin/perl5
cd /tmp/LMS/slimserver-vendor/CPAN
./buildme.sh | tee /tmp/LMS/buildme.sh.log
cd /tmp/LMS/logitechmediaserver-7.9.0-1438870722/CPAN/arch/5.20
cp -Rp /tmp/LMS/slimserver-vendor/CPAN/build/arch/5.20/amd64-freebsd-thread-multi .
rm -rf i386-linux-thread-multi
rm -rf i386-linux-thread-multi-64int
rm -rf x86_64-linux-thread-multi
cd ..
rm -rf 5.8
rm -rf 5.10
rm -rf 5.12
rm -rf 5.14
rm -rf 5.16
rm -rf 5.18
cd /tmp/LMS
tar cf logitechmediaserver-7.9.0-1438870722_with_fbsd.tar logitechmediaserver-7.9.0-1438870722
In FreeNAS shell:
cp /mnt/SSD/jails/build_jail/tmp/LMS/logitechmediaserver-7.9.0-1438870722_with_fbsd.tar /mnt/SSD/jails/LMS/tmp
In LMS jail:
pkg update
pkg upgrade
pw groupadd -n lms -g 30001
pw useradd -n lms -u 30001 -g lms -s /usr/sbin/nologin -c "Logitech Media Server" -d /nonexistent
mkdir /usr/local/lms
tar xf /tmp/logitechmediaserver-7.9.0-1438870722_with_fbsd.tar -C /usr/local/lms
mv /usr/local/lms/logitechmediaserver-7.9.0-1438870722/* /usr/local/lms
rmdir /usr/local/lms/logitechmediaserver-7.9.0-1438870722
chown -R lms:lms /usr/local/lms
rm /usr/bin/perl
rm /usr/bin/perl5
I created an additional storage source /mnt/SSD/lms_data with destination /mnt/lmsdata and set permissions:
chown -R lms:lms /mnt/lms_data/cache
chown -R lms:lms /mnt/lms_data/prefs
Create startup file: lms
This is trickier than it looks because it can't have any extra white space. I suggest getting it from the pastebin link up there ^^^^ (I'd put the link but I don't have enough posts)
Follow the instructions in the file.
mv lms /usr/local/etc/rc.d/
chown root:wheel /usr/local/etc/rc.d/lms
chmod 555 /usr/local/etc/rc.d/lms
echo 'lms_enable="YES"' >> /etc/rc.conf
echo 'lms_cachedir="/mnt/lms_data/cache"' >> /etc/rc.conf
echo 'lms_prefsdir="/mnt/lms_data/prefs"' >> /etc/rc.conf
echo 'lms_playlistdir="/mnt/Playlists"' >> /etc/rc.conf
Restart your jail and try to connect to the jail's ip address : 9000
Thank you Roger Wilco for writing the original step by step process!! Also thank you to Get Amped for your amended version - I am now up and running! Scanning music now... :)
PS: I also had to install sox (pkg install sox) to get my FLAC-FLAC transcodes working.
DrMacabre
hello,
I've been following step by step all the information in the topic and all i get when trying to manualy start the service is :
root@LMS:/ # service lms start
lms does not exist in /etc/rc.d or the local startup
directories (/usr/local/etc/rc.d)
i have created the lms file using textwrangler and pasted the content of the startup file from Roger Wilco, setup the permission without getting any error.
I'm totally lost since i have almost no clue about what i'm doing here :/
EDIT : nevermind, i'm such a noob, i created the lms file outside of the jail... got it working now.
Vincèn
Followed all instructions but refuses to start :( the slimserver.pl exists well, I double-checked !!
root@SlimServer:/usr/local/etc/rc.d # service lms start
Starting lms.
/usr/local/lms/slimserver.pl: not found
/usr/local/etc/rc.d/lms: WARNING: failed to start lms
Get Amped
Starting lms.
That can happen if there is any white space at all in the lms file. How did you create it?
