Daisuke
- Jun 23, 2011
If I move or unset the Kubernetes pool, I expect the old dataset to be destroyed. It is not, on top of that the dataset content is duplicated, adding 1GB every time I move the pool to
I opened NAS-119574. For now, I'm manually deleting that dataset after moving it. If you have a large
ix-applications dataset. After move, the dataset is now 2GB, previously it was 1GB on a clean Bluefin install, with no apps installed.
ix-applications dataset and you moved it several times, you can end-up with unjustifiably taken space from your /mnt/pool.
