madin3
- Mar 14, 2017
Sorry I do realize this issue has been discussed in the past and I have read some of them, but I am not able to find the right resolution or determine what my pool configuration is. It's been a while since I created the pool and was not paying attention to the requirements. Thank you.
ISSUE: I would like to replace any one of the 2TB disks with a 4TB disk.
When attempting to take a disk (not corrupted) offline: Pools -> Pool Operations -> Status -> Offline -> Offline Disk -> Confirm:
I get an error message:
CallError
[EZFS_NOREPLICAS] no valid replicas
zpool status results:
Last login: Tue Jun 20 18:55:16 on pts/12
FreeBSD 13.1-RELEASE-p7 n245428-4dfb91682c1 TRUENAS
TrueNAS (c) 2009-2023, iXsystems, Inc.
All rights reserved.
TrueNAS code is released under the modified BSD license with some
files copyrighted by (c) iXsystems, Inc.
For more information, documentation, help or support, go here:
truenas.com
Welcome to FreeNAS
Warning: the supported mechanisms for making configuration changes
are the TrueNAS WebUI and API exclusively. ALL OTHERS ARE
NOT SUPPORTED AND WILL RESULT IN UNDEFINED BEHAVIOR AND MAY
RESULT IN SYSTEM FAILURE.
root@PROLIANT:~ # zpool status
pool: MyNAS
state: ONLINE
scan: scrub repaired 0B in 19:49:47 with 0 errors on Sun Jun 18 19:49:56 2023
NAME STATE READ WRITE CKSUM
MyNAS ONLINE 0 0 0
gptid/2074d41a-bbd1-11e6-a233-00262d01f860 ONLINE 0 0 0
gptid/b10710d6-c237-11e6-a544-00262d01f860 ONLINE 0 0 0
gptid/388d8965-ae6b-11e9-9bf2-9418823802ac ONLINE 0 0 0
gptid/5394403f-ca0c-11ea-9f36-9418823802ac ONLINE 0 0 0
errors: No known data errors
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0B in 00:34:30 with 0 errors on Tue Jun 20 04:19:30 2023
Freenas-boot ONLINE 0 0 0
Da0p2 ONLINE 0 0 0
Errors: no known data errors
root@PROLIANT; ~ #
CallError
TrueNAS | Mission-Critical Open Enterprise Storage
Transform your data estate with TrueNAS Enterprise storage appliances. Secure, scalable, high-performance data platform for every workflow.
Welcome to FreeNAS
pool: MyNAS
state: ONLINE
MyNAS ONLINE 0 0 0
pool: freenas-boot
state: ONLINE
Da0p2 ONLINE 0 0 0
root@PROLIANT; ~ #
