Savell Martin
- Jun 10, 2013
OK i'll have a play today and get back to you :)
Thanks for the help
Thanks for the help
Hey Josh,
Quick question. I have a spare 320gb drive attached that I want to use for my download/Jail drive.
How do you set it up in FreeNas for this?
In Volume management do you just set it up as a spare drive? Then create a new Jail using that volume and install all apps to this?
Can I then get it to post process over to another volume IE. My main volume with all my data?
Sorry another question, would it be possible for you to create a clone of SickBeard so that it can run off another fork for anime?
Specifically this branch: http://sickbeard.lad1337.de/
I'm moving away from a Synology nas, and the guy making the packages for this has a separate SB install, and then it just asks you to put in the github url for the fork.
It then gives it a different port number so its not the same as origional SB.
Would this be doable at some point in the future?
I can't seem to reproduce this. When I install CouchPotato it updates to the latest version during the install process.
You can try the below commands to re-download the CouchPotato source.
Code:rm -r /usr/pbi/couchpotato-amd64/share/couchpotato/CouchPotatoServer fetch https://github.com/RuudBurger/CouchPotatoServer/archive/master.zip unzip master.zip -d /usr/pbi/couchpotato-amd64/share/couchpotato rm master.zip mv /usr/pbi/couchpotato-amd64/share/couchpotato/CouchPotatoServer-master /usr/pbi/couchpotato-amd64/share/couchpotato/CouchPotatoServer chown -R media:media /usr/pbi/couchpotato-amd64/share/couchpotato/CouchPotatoServer
UPDATE (1/26/2014)
- XDM (new)
- SickBeard / HTPC-Manager v2.1
- Replaced libjpeg with libjpeg-turbo
- Removed unnecessary dependencies
- Headphones v2.1
- Compiled with optimized CFLAGS
no reason too. I replaced a library that might help with image manipulation performance.Hey Joshua,
I have Sickbeard v2.0 of your plugin installed. Is there any reason to upgrade to v2.1? If so, would I have to uninstall and reinstall the plugin (backing up my configs of course)?
Thank you!
I still haven't tested if in place upgrades break stuff. but yeah, backup of etc/sickbeard is always good.
Is there any guide on how to configure headphones. Or how headphone works?
And when headphone search for things im getting 403 forbidden for the pirate bay for torrents. Because my nzb site doesnt have the particular type of music available. Is there a way to enter other torrent sites that are not listed within headphones?
Josh i was meaning to ask...
Why are you waiting for/using nzbToMedia?
Surely these days all our hardware should be more than powerful enough cope with the built in post processing?
Also you are adding complexity and reliance on another plugin?
What if they break it, or if a SB update comes out and breaking it?
It just means more work for you... Surely the built in processing is more than adequate?
Just wondering?
dumb question... htpc-manager and xdm are in the same ports?8085? It's correct ?!?!
Thanks
Non of these questions are FreeNAS specific so you may have more luck asking in other venues.
this thread might be helpful http://forum.xbmc.org/showthread.php?tid=103688
Ok. by any chance you know how to add a custom torrent or we can only use the torrents listed in headphones?
Another question.... Is CouchPotato updating through Git? I've tried updating through the GUI of CouchPotato but it doesn't seem to be updating the files.
I noticed this when I started getting errors with nzbToMedia. Clinton had updated nzbToMedia to work with the latest version of CouchPotato but I was getting errors because it wasn't the latest, even though I thought it was.
Please have a look at the issue I posted on GitHub: https://github.com/clinton-hall/nzbToMedia/issues/250
Is there something I'm doing wrong with installing the CouchPotato plugin? Or is there a way I can update through Git?
